Results 11 to 20 of 42
- Apr 2015
- 75
May 5th, 2015 05:43 AM #11
- Apr 2015
- 75
May 5th, 2015 05:52 AM #12I also noticed that this version of the Sportage is stripped-down. No DRL (previous model has it), no side-repeater (previous model also has it), not sure about the other ommissions. The only positive addition is the rear aircon vents.
The Tucson feels bigger (subjective?), new engine (more fuel efficient?), didn't notice the drl/projection lamps in this trim. The downside is that it will be replaced by a newer one in the next few months, which would make this current model outdated. Any news on when they're face-lifting the Sportage?
Both seem lacking in the safety department...
May 5th, 2015 06:21 AM #13
kia interior makes it feel small. tucson interior is better imo.
kia will introduce the tiger nose on the sportage next year. they just released the sorento with the new design philosophy soon its younger sibling will get.
mega savings on the older models. the tucson looks fine as long as there is drl hehehe. dont worry about the a/c, vkool tints fixes that.
- Jun 2014
- 414
May 5th, 2015 08:12 AM #14
- Jun 2014
- 414
May 5th, 2015 08:27 AM #15While it is true that diesel engines are noisier than gasoline engines, once you are inside the difference is insignificant.
The advantages of a diesel engine far outweighs this minor disadvantage. This is the reason why diesel powered cars are relatively more expensive. The maintenance cost difference is not that significant.
- Jun 2010
- 466
May 5th, 2015 09:45 AM #17For some reason, i feel the kias drive better. Haven't driven the tucson with the Nu engine though. The theta is pretty decent. Test drive both, they actually feel different even if they are practically twins.
- 52,731
May 5th, 2015 09:52 AM #18- - - - - - - - - - - - - - - - - - - - - -
diesel engines are naturally noisier than gas, by virtue of their design. and only the user can decide for himself if this added noise and vibration is acceptable. some will pick on it simply because they have to come up with something negative.. heh heh.
diesels cost more, because they are more expensive to manufacture. whether this higher cost is acceptable or not, is something only the buyer can decide on.
acceptable cost of repair and maintenance? now, that's one hot issue still under heavy debate.
why do i like diesel? ...bahain samen... for whatever real or perceived advantage the diesel has against floods..Last edited by dr. d; May 5th, 2015 at 09:57 AM.
- May 2015
- 10
May 5th, 2015 11:15 PM #19
- Apr 2015
- 75
May 6th, 2015 10:27 PM #20
