Results 21 to 27 of 27
- May 2005
- 234
August 26th, 2009 08:56 PM #21i pulled through with isuzu 4JG2 normally asperated engine from isuzu elf..now does anybody have an idea of rear axle ratio of isuzu elf with this engine?what can you guys say about the performance of this engine?would really appreciate your info.
- Oct 2009
- 1
October 6th, 2009 12:51 PM #22I am looking for a cylinder head for Isuzu 4JG2 engine. Where can I buy it in Manila or Davao city? I am from General Santos city. What is its estimated cost? Thanks.
- Oct 2010
- 1
October 27th, 2010 12:24 PM #23Good Day!
I'm having trouble deciding what type of differential will i put in my 4dr7 engine.
Hoping you guys can help and give me advice.Last edited by 4dr7; October 27th, 2010 at 12:25 PM. Reason: wrong spelling
- Apr 2011
- 1
April 8th, 2011 08:57 PM #24Mga sir tanong kulang kng anu magandang ratio ng diffrential para sa 4DR7 na engine? Rim 15inch 205 size ng gulong.
Thks
Jo-Fox
- Jun 2005
- 59
May 5th, 2011 06:38 AM #25try nissan TD27 turbo or NA as my experience its very reliable pero medyo may kamahalan lang.4dr6 are very reliable engine also and 4dr7 but truck talaga feeling nito na engine tagal bumaba ng rpm so medyo may delay ka shifting any gears.
- Jun 2012
- 1
June 7th, 2012 05:00 PM #26[QUOTE=doctor backyard;1285178]just added info, 2LT engines use high pressure cooling systems, kailangan nila ang matigas na pressure cap... more than 0.9 lbs. rating
4DR7s are workhorse engines of Mit. Canters 2.0...low speed, you can barely use the 1st gear. maingay ang transmission (low helical angled gears) ...ask for parts availability[/Q
long-stroke engine ang 4dr7 malakas ang makina.. it depends na lang sa trans. at defrential kung mag match ito sa makina.. tsaka ndi naman ganun kaingay ang trans. nito.
August 19th, 2012 10:27 AM #27
I have a Mits. 4dr7 engine mated with a 4d32 tranny.
Anybody here know what the valve clearance for the 4dr7 is?
Can't seem to find full specs on the webfor this engine kasi.. TIA
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
