Results 41 to 48 of 48
November 27th, 2008 12:41 AM #41
We're hoping there will be. As it is, power gains with a piggyback are limited by a very intrusive ECU that pulls boost whenever the car starts getting hot. That's the lingering problem for the Tuason Racing Diesels... as the easy cure, alcohol injection, is prohibited under PTCC rules, and would just add another fluid that needed topping up every pitstop.
Still... the thing is dynamite when it's on-boost...
Tsikot Member Rank 3
- Aug 2004
- 2,452
November 27th, 2008 12:09 PM #42ser Niky, i've seen in the SpeedLab website that they've installed this "Alcohol Injection" to a Mazda MPV and Hyundai Sta Fe. Dyno charts also showed both huge gain esp. for the MPV, not so much with the Sta Fe as probably it was already working much more efficiently out of the factory. do u know of any one installing it in their Focus TDCi?
is this the same principle as the WRX/STi water spray for the intercooler?
also is it practical to use (isn't it too trouble some to keep loading up with water/alcohol all the time?) also i've seen in the chart comparison between water and alcohol, u only get little gain when using the latter. so better stick with water.
November 27th, 2008 06:04 PM #43
IIt's not practical per se, but every little bit helps on the racetrack or dragstrip.
- May 2006
- 316
December 2nd, 2008 12:41 AM #45
I don't know if it's on only at full throttle or active at even half throttle... but when the ECU senses that you want more power, it'll raise the power by about 20 Nm (for up to 10 or 20 more horsepower) for around 5-10 seconds.
- Oct 2007
- 83
December 2nd, 2008 10:57 AM #46I think we're trying to compare a bayabas with a kaimito here. 1.6 vs 2.0L engine? Sport version vs standard car?
IMHO, there is no comparison.
Better if you compare the i30 with, say a Mazda hatchback.
Focus TDCI sport has an illustrious rallye pedigree..........tuned for everyday city driving. After seeing the Focus DSG tranny, there's no need to look any further.
Worse, the i30 breached the P1million mark.
Overpriced vs real value for money.
No comparison.
Sorry. Just an opinion lang po.
- May 2006
- 316
December 6th, 2008 08:48 PM #47
- Dec 2008
- 421
December 9th, 2008 05:12 PM #48The i30 and the Focus TDCi are both great cars.
Overall the focus TDCi slightly edges the i30 out but only by a very narrow margin. But for nearly half the price of the focus (the price abroad), the i30 is the best value for the money. Unfotunately here in the philippines they're both priced at about 1M
You just unregister the device where its currently installed.
National ID Law
