Results 41 to 47 of 47
August 1st, 2008 12:58 PM #41Napansin ko lang na ang daming mali sa car specs nung C! comparo.
- Jun 2004
- 207
August 4th, 2008 01:32 AM #42Look at the SPECIFICATION section of each cars they tested.
[SIZE="3"]Honda Civic 1.8S[/SIZE]
Max Power:
C!: 138hp*6300rpm
Honda: 140hp*6300rpm
[SIZE="3"]Ford Focus 2.0L TDCi[/SIZE]
Wheelbase:
C!: 2650mm
Ford: 2640mm
[SIZE="3"]Toyota Corolla Altis 1.8V[/SIZE]
Max Power:
C!: 130hp*6000rpm
Toyota: 132hp*6000rpm
Engine:
C!: 1.8L DOHC 16V Inline-4 / Dual VVT-i
Toyota: VVT-i, 4-Cylinder In-Line DOHC, 16 Valve (we got the old engine and not the Dual VVT-i that most first-world countries received)
[SIZE="3"]Mitsubishi Lancer EX GT-A[/SIZE]
Max Power:
C!: 152hp*6000rpm
Mitsu: 153hp*6000rpm
Curb Weight:
C!: 1415kg
Mitsu: 1385kg
Tinamad na kong hanapin pa yung sa Mazda3 2.0R at Subaru Impreza 2.0R.
August 5th, 2008 11:24 AM #43
Mitsubishi Lancer:
There's a fair bit of chicanery in quoting weights, as weights will differ between trim versions and transmission set-ups. Minimum weight for a 2.0 MT is 1320 kgs. Minimum weight for an AT is about 1410. C!'s tester is an AT with 18" wheels. Maybe the subwoofer adds 5 kgs (on the Mazda MP3, the subwoofer and 17" mags added 15 kgs to the dry weight)
Of course, since this is all "dry" weight, it's anyone's guess what actual weight is.
Also, there's some fudge factor in converting PS to HP. The official power output of the Lancer is measured in PS. Divide that by 1.01387 and you get HP, which is: 152.8795950113987.
Mitsubishi rounds this number up (which is more correct) to 153 hp (which is technically correct). Most publishers round this number down to 152 hp, which is still relatively correct.
Honda Civic
Some markets quote the Honda Civic 1.8 at 103 kw, which is 138 hp. Why this difference exists, I don't know.
Remember, power ratings are suggestive and based on a manufacturer's own testing. These may be subject to change given different testing regimens (Japanese power quotations don't completely follow US SAE procedures yet, which is where Honda and Toyota got burned before) and different gasoline types and emissions requirements.
Ford Wheelbase: apparently, they've got that one completely wrong. By a whole 10mm.
August 6th, 2008 12:12 PM #44
Biggs, Thank you for elaborating. This needs a call to C! Magazine editors
You lazy blokes!
- Jun 2004
- 207
August 9th, 2008 02:50 AM #45
August 11th, 2008 09:23 AM #46
when in doubt about HP figures, you could always have it baseline dyno'ed in Speedlab and/or Autoplus.
August 11th, 2008 02:40 PM #47
Won't do you much good. Dynos can't accurately tell you bhp. They can only state whp (which will also vary from dyno to dyno) from which you can infer bhp. It gets even worse when you consider that modern cars have ultra-efficient transmissions, which makes calculating bhp even more problematic (higher efficiency transmissions give an extra 5-10% power over older ones).
And from dynos of the Focu TDCi, it apparently makes 160 bhp.
Traffic!
