View Poll Results: Which of the following might be best for a single guy in late 30s, etc?
- Voters
- 29. You may not vote on this poll
Mitsu Lancer EX GTA 2.0L CVT
12 41.38% -
Ford Focus 2.0L TDCi A/T
12 41.38% -
Subaru Impreza 2.0RS A/T (sedan)
1 3.45% -
Subaru Impreza 2.0RS A/T (hatchback)
4 13.79%
Results 31 to 40 of 48
January 20th, 2010 06:00 PM #31
But I am not going to modify this car as heavily as I have had my previous cars. A little more power, better brake pads, maybe nicer looking wheels and that's it.
Isn't the Lancer supposed to get cheaper in the future due to production moving to our shores?
And even if they do push through with the open trade, I think the prices will not go down. The dealers will just add more toys and "options" as standard equipment (example: leather seats & steering wheels & electric folding side mirrors) on lower model cars so they can maintain their selling prices.
January 20th, 2010 09:09 PM #32
January 21st, 2010 12:56 AM #33
January 21st, 2010 01:27 AM #34
January 21st, 2010 10:51 AM #35
I'd love one myself... but GH wants a matic... I've tried to talk him into a manual, but he won't budge. And sadly, the 2.0R is a boring drive in AT.
If you're into modification...I hear the Focus is a dead end in terms of suspension. CMIIW
I don't know if the current Focus shares the new revo-knuckle geometry that the RS has, though... and the ride height and spring rates for the Teins may not match the nose-heavy Powershift.
January 21st, 2010 06:05 PM #36
January 21st, 2010 06:20 PM #37
January 21st, 2010 06:26 PM #38
I think most people would give up that 4/10th of a second to reach 100kph advantage to have the ease of being able to let the machine do the shifting for you, especially in traffic.
Also, how consistent can you be in accelerating a car with M/T from 0 to 100kph run after run? The Focus w/ DSG would probably do consistently the whole day if it didn't overheat the tranny.
January 21st, 2010 06:46 PM #39
exactly, the whole point of the DSG tranny is super quick shifting in an auto style tranny. convenience and performance, at the same time.
January 21st, 2010 07:15 PM #40
The Focus PCD is 100x5. ROTA carries mags in that PCD, but the selection is very limited.
Depends.
Stock to stock, the Powershift is 2-4/10ths slower than the manual. This is because you can generate tire slip with the manual transmission. With the Powershift, even with the ESP turned off, you only get a little tire slip, so you bog down below the powerband. It also won't let you maximize each gear like you can with the manual. Even if you're not getting much power in the high rev range, you're still getting more power in a lower gear than in a higher one.
Modified, you don't want all that tire slip anymore. The TDCi will overspin the stock tires in the top of first and second gears. The launch advantage of the MT disappears, but then you won't be able to modulate the clutch and shifts on the Powershift, so there's still a small advantage.
The big advantage for the Powershift is on the racetrack or in the hills, as it allows you to concentrate on driving fast. In hard driving, it's easy to get lost between gears in the 6-speed Focus. It also allows you to left-foot brake, if you know how... which gives even more benefits in terms of corner speed.
And despite the heavier nose (the Powershift is some 40-60 kilos heavier than the old TDCi), the Powershift has an advantage in terms of cornering speed due to the revised suspension. They've fitted it with taller and stiffer front springs, which make it less nose-heavy and more nimble than the old car.
1st time to do rotary machine polishing? give a try first in 1 section like sa bubong, that even...
"Tamang OC lang" - a newbie's guide to car...
