Results 31 to 40 of 52
June 29th, 2017 06:31 PM #31
How about better quality interior of the vios compared to the plastic interior of mirage.
Ground clearance is also higher sa mirage kaya di masyado sumasayad. Pero malambot din ang suspension ng mirage.
June 30th, 2017 02:43 PM #32
Higher quality?
If we're talking the 1.3E... only marginally so.
Both cars have relatively soft suspensions, but the Vios is slightly better in this regard. You'll only really feel it with a full load of five plus luggage. With the Mirage, four on board already causes a significant drop in ride height.
June 30th, 2017 07:31 PM #33
- May 2017
- 31
July 1st, 2017 02:00 PM #34Thanks guys. Tingin ko rin kay vios is good. Since.mrmi gmgmit. Means ok din tlga.. my friend has a vios 1.3E. Naalala ko yung sa suspension n yan. May nangyari n nalubak sya then bumigay suspension. Knowing that halos bago pa vios nya.. and lagi nya reklamo is lakas daw s gas.. dahil lumaki daw body ni vios.. pero kht pano thumbs prin ako kay vios.. since prehas ko nmn sya tiningnan. Di ko nga lang na test drive..
Sent from my SM-G610Y using Tsikot Forums mobile app
July 1st, 2017 02:12 PM #35
So ano pinili mo?
Kung g4, may solution sa soft suspension. Palitan lang ng kyb springs.
- 52,731
July 1st, 2017 07:19 PM #36
- May 2017
- 31
July 2nd, 2017 02:20 AM #37I believe.. it's AT..sir
- Mar 2017
- 655
July 4th, 2017 09:41 AM #38
- Nov 2014
- 1,269
July 4th, 2017 12:26 PM #39
July 4th, 2017 12:54 PM #40
May kilala din ako na bumili ng stock spring ng swift at kinabit nya sa mirage. Could be the same person but unlikely.
