Results 31 to 40 of 40
- Aug 2017
- 232
November 20th, 2017 12:22 AM #31SUCCESS! 😂 tried to put in L when going downhill.
Sent from my EVA-L19 using Tsikot Forums mobile app
November 20th, 2017 02:25 AM #32
Sorry.
Lift off the pedal before you hit the hump para weight ng car nasa likod na. Thus, less suspension action (ang intense neto) sa front.
Sent from my SM-G930F using Tsikot Forums mobile app
November 21st, 2017 12:33 AM #33
CVT ba, once na override into manual mode, effective ba ang engine braking?
November 21st, 2017 01:16 AM #34
November 21st, 2017 11:27 AM #35
If a bump or pothole gets you by surprise and there's not enough distance to brake to a full stop, firmly step on the brakes anyway to bleed off as much speed as possible and let go just before you hit the bump/pothole. That will usually prevent or lessen suspension and wheel damage.
That said, you should only do it if there's nobody tailgating you. If it's a trailer truck, forget it! You stand a better chance just running over the bump/pothole than to get rear-ended with solid steel.
Then there's also those rare potholes that you can practically "skip" or fly over when going fast enough. Braking in this case, might even be detrimental. Experience will teach you which road imperfections requires you to slow down and which ones can be taken at a faster speed.
What you do depends on your environment.Last edited by oj88; November 21st, 2017 at 11:29 AM.
- Jul 2012
- 233
November 21st, 2017 11:44 AM #36pano naman po malaman kung nag-engage ABS? may indicator ba yun? or mararamdam sa behavior ng oto?
November 21st, 2017 11:50 AM #37
November 21st, 2017 12:10 PM #38
Brake light flashing usually indicates Brake Assist is activated ...
- Jul 2012
- 233
November 21st, 2017 02:00 PM #40ah nice thanks i haven't experienced ABS yet, good to know in advance, baka kasi bigla ako magpanic pag naramdaman ko hehe
Suzuki JIMNY [merged threads]
