Results 21 to 30 of 40
- Aug 2017
- 232
November 18th, 2017 10:46 PM #21Wala na kasing owner's manual. Sige, will just try again tomorrow Thanks!
Sent from my EVA-L19 using Tsikot Forums mobile app
- Jul 2016
- 939
November 18th, 2017 11:52 PM #22Should be same with your innova 4AT...
How to Shift Gears in Toyota Fortuner | CarDekho.com - YouTube
- Aug 2017
- 232
November 18th, 2017 11:54 PM #23Thanks! Appreciate it.
November 18th, 2017 11:56 PM #24
just know if your brake pads and drum shoes need replacing...
November 19th, 2017 07:34 AM #25
Safest way to brake is to just step on the pedal firmly. Modern braking systems are designed to let ABS and EBD take over during panic braking situations - all you need to do is press that pedal hard.
For more experienced drivers, you can apply threshold braking - the point where braking power is at its maximum without trigerring ABS. Takes a while to get used to but it's very useful on the track.
November 19th, 2017 11:14 AM #26
Let's make it more complicated pa! Haha
You can play with your car's balance. You can shift the weight around when you brake.
For example, just before you go over a hump, depress the pedal to shift the car's weight to the rear, thus for a smoother entry over the hump.
Lol! 😂😂😂
Sent from my SM-G930F using Tsikot Forums mobile app
November 19th, 2017 12:28 PM #27
November 19th, 2017 12:50 PM #28
Sorry, what i meant was lift your brake pedal for a smoother entry sa hump. Hahaha
Basta apak brake, yun na yun. Lol
November 19th, 2017 01:54 PM #29
Thank you!
