Results 11 to 19 of 19
- Feb 2010
- 336
October 19th, 2010 11:07 PM #12may i suggest additional options to the TS: i can best describe the units below to be a Multi-Purpose All-Around Vehicle (both Shuttle and/or Delivery): all good price just haggle for discounts or freebies;
1) KIA KC2700 - the biggest in the bunch, i owned one before & i tell you maintenance & parts is cheap kahit sa casa pa, good performance, big configuration, engine under the seat..
2) Hyundai H100 Porter - same also w/ KC2700 but the brand speak for itself, same w/ KIA PMS, big configuration also, engine under seat..
3) Mitsu L300FB - its a well-known brand for this kind of business, engine under seat, mid-size config because of its body..
4) Isuzu IPV - tried and tested engine, mid-size config., engine infront..
5) Toyota Hilux-FX - predecessor of first gen FX but with newer engine infront.
sayang naman if brand new van gagawin mo delivery once in awhile. consider also the shocks, suspensions parts, underchassis components if you want it for long-term use...HTH!
- Jan 2008
- 4,726
October 19th, 2010 11:19 PM #13ingat lang sa L300FB... madalas malaglag ang ball joint nyan!! dami ko na nakikita nyan laglag ang ball joint sa gitna ng kalsada...
mas ok ang KC2700 or H100.. malaki pero class ang dating..
- Sep 2008
- 630
October 19th, 2010 11:23 PM #14If the seating capacity if urvan suits what you need and the cargo space is enough for you then go for it, but if it is not enough go for h100.
I my self wouldn't suggest the new FX (hilux) for your needs, it has more expensive maintenance than your other choices which is its down side, but in return you get the power and the looks. But you don't need that much power, the power of 4D56, TD27, 4JA1 is just enough.
- Aug 2009
- 73
BANNED BANNED BANNED
- Jul 2010
- 1,114
October 20th, 2010 03:35 AM #16ok sana yun isuzu lpv, pero mas ok kung crosswind ang isaksak nila sa harap
- Apr 2008
- 6,237
October 22nd, 2010 12:22 AM #17The H100 is really nice. May naririnig ako na mas reliable daw ang engine ng H100 kesa sa K2700 (magkaiba sila ng makina), mas madaling ma-overheat daw ang K2700. At pagdating sa dealer, alam natin na Hyundai is the better one, with better deals and better after sales service. Mas malaki ang NHR-PV, pero di ko sure kung ginagamit na dun ang turbocharged 4JB1 na ginagamit sa mga dropside na NHR. Kapag normally aspirated engine, kasing lakas lang yan sa H100.
October 27th, 2010 12:06 AM #18
sir suggest lang...ito ung pro and cons nung suggest ko 2 van kung pang biyahe (pampasahero) din
sa nissan urvan (pros)
- mura
- mabilis makahanap ng pyesa
- mababa lang ang down at monthly (mga 23k monthly at 200k down)
(cons)
- mostly sabi ng mga urvan owner mabilis daw mag overheat ung van, may kakilala ako, urvan inakyat ng baguio 10 passengers, nag overheat sa gitna ng marcos highway. brand new nila kinuha ung van
- mostly sa nissan urvan, sabi ng mga kasamahan ko, underpower daw, at malakas sa gas due to its 2.7 engine.
sa Toyota Hiace Commuter ( pros )
- malakas ang makina, dahil powered ng computer box.
- fuel efficient dahil sa 2.5 turbo engine nito, at malakas na humatak, tipid pa.
- toyota, kaya sure na tatagal ung van.
- mas may dating ung porma ng van
(cons)
- medyo malaki difference sa downpayment at monthly ( ung sa amin, 22,000 ang monthly, 290k downpayment all in na sir ).
- dapat alaga, dahil pag nasira, idadamay ung computer box, witch is important sa car.
sir, suggest ko lang yan, nasayo padin ung desisyon base on your budget
- Apr 2010
- 12
October 27th, 2010 02:56 AM #19Mga sir alin kaya sa mga van na to ang may pinakamataas na head room.. yung kasya ang ang cruiser bike na 5 feet ang taas (may wind shield kasi) tnx
