Results 1,431 to 1,440 of 1594
May 28th, 2019 09:04 AM #1431
I have observed that it is better to just leave the car in D and just modulate the throttle to optimal output. Even with our old slowpoke Jazz 1.3L AT, I didn't have any issues going up steep building ramps if I put it in D. This is for the usual automatics.
For DCT, the car will be intelligent enough to stay in second gear or third gear when traversing steep ramps. For CVT, just keep the throttle steady and the tranny will put you in the right gear.
May 28th, 2019 09:19 AM #1432
Maybe. But I have yet to see an A/T that has a 2 or L2 which cycles through 1st gear.
If you read almost any owners manual, 2ng gear is typically used to get out of slippery surfaces, like snow or sleet. The reason being, 1st gear has too much torque in it so you will have to do extra work managing the gas pedal to avoid slipping. 2nd gear inherently reduces the torque available at the wheels and it makes it easier to accelerate without slipping.
If 2 or L2 cycles through first gear, it won’t make any sense under these situations.
May 28th, 2019 09:32 AM #1433
Believe me, in dry snow or icy surfaces, no amount of torque will help once you lose traction from your tires, even if you are driving an AWD or 4x4 vehicle. Such conditions are even worse for RWD vehicles. In snow surfaces, proceed only when you can establish grip from all 4 tires. Once you lose traction or grip, ease on the throttle and steer the car to slow down the slide until such time you get traction back. Don't ever, ever brake or your vehicle will become a battering ram to the vehicle in front of you.
May 28th, 2019 09:33 AM #1434
Going up a short incline in a parking structure is totally different from an uphill drive that spans hundreds of meters.
In a short incline, you’re likely doing no more than 20 to 30kph. “D” is fine as it probably won’t shift up beyond 2nd gear.
But on long and winding uphill highway the likes of Kennon Road, you’re likely doing 50 or 60., at least. That may cause your transmission to oscillate between the last two gears. This is especially exacerbated when the vehicle is loaded to capacity. “3” or “D3” will prevent the transmission from going to overdrive, only to lose power and then shift back down again, wash rinse, repeat.
May 28th, 2019 09:35 AM #1435
May 28th, 2019 10:09 AM #1436
- Jul 2019
- 6
- Jul 2019
- 5
July 29th, 2019 11:40 AM #1438Most of my friends tend to go with A/T due to heavy traffic considering their cars are mostly used for city driving. Same for me, but also because of ease of use.
- 54,320
July 29th, 2019 12:22 PM #1439
- May 2006
- 1,668
July 29th, 2019 02:04 PM #1440MT on Mondays and Sunday.
AT on other days and saturdays
Mas fun yun MT above 3k rpm.
I can attest that these tablet types don't leave any marks nor is it harsh on the washer system. I...
Windshield Washer Fluids Talk
