Results 11 to 20 of 39
November 6th, 2006 11:07 PM #11
otep,
yap there is. i sourced the info mostly there so i decided to have this as my choice
m_ron,
will do ask. hehe..
where will be the compression test be took?.
it has already projectors on. and i think the black part is too painted.
November 6th, 2006 11:15 PM #12
I think it's a *must* to do a compression test on the audi since he already upgraded the turbo and ecu.Bring it to a knowledgeable shop that can do a compression test with ofcourse permission from your friend.
November 6th, 2006 11:38 PM #14
AFAIK, Central Diesel along Quezon Avenue can do compression tests. PM mo si Dieseldude.
November 6th, 2006 11:55 PM #16
search mo lang. afair, merong nakapost dito na na tel no. nung malapit na shop sa balintawak.
Tsikot Member Rank 4
- Jul 2003
- 1,082
November 6th, 2006 11:59 PM #17odell,
ito ba un audi a4 na nasa madrigal st. in Ayala Alabang?? may nakita kami na 1.8T 550k manual tranny rin, black.
id get the A4... gwapo e. plus it ages well compared to the cefiro.
November 7th, 2006 08:38 AM #18
Yup, this can save you a ton in headaches and repairs... most decent shops carry a compression tester (do a dry and wet test); try checking Autotechanika, Speedyfix, etc... Lift up the car as well to do an underchassis inspection as you can find things like leaks and underchassis hits/stresses.
November 7th, 2006 03:33 PM #19
*DITTO* on the compression test for the Audi... sad thing that a compression tester is such a simple thing, but so hard to find at the automotive stores here (Have been looking for years, want one for my own garage...)
^cheap... $31 only...
If the guy didn't put too much boost into the Audi (i.e.: if it's around just 180 or so...) and it tests okay, I'd go for that one. More potential, for one, and for another, definitely less headaches registration-wise and set-up wise than a swapped car. (you never know how good the swapped surplus engine is...)
And since you're already used to owning cars with poor dealer support (Volvo? Hehe...), then the wait and search for parts won't be an issue with you, right?
Plus, it's fully set-up already. Less work for you... and more fun to drive...
Make the Cefiro swap a 3.0 MT, though, and I might change my mind...
- Feb 2005
- 68
November 7th, 2006 03:44 PM #20Ayaw mo ng 3-Series or Accord/Camry na lang? They're certainly better cars than your choices.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
