Results 31 to 32 of 32
- 52,523
December 23rd, 2019 04:41 PM #32
Tiny econoboxes need space & cost optimized. FWDs have tranverse engine layout...allows shorter frontend, less sheet metal. No prop shaft, no rear differential, lesser parts. CHEAPER for manufacturers. This & the efficiency of direct drive, though great marketing points, won't outweigh the pluses of RWD. FWD, despite its practicality, has greater performance, maintenance & longevity handicap. You have torque steer, understeer, quicker front tire wear to name a few. With steer & drive chores crammed upfront, FWDs tend to wear out faster than the simpler RWDs. More frequent alignment tweaks & part swaps are expected in FWD ownership. All those make them lesser seen in the perf premium, pickup/PPV, & larger luxury segments. RWDs, however, can consume rear tires prematurely....esp if one DRIFTs.
With the pros/cons known, hands down, RWD>FWD.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
