Results 21 to 30 of 32
- Aug 2017
- 49
September 6th, 2017 09:58 AM #21Malakas daw kasi sa gas ung ph16 kaya siya nagpalit.
Sent from my F3216 using Tsikot Forums mobile app
September 6th, 2017 10:10 AM #22
^ hindi naman. Matipid nga iyong ph16 ko dati. Bulletproof pa basta wag lang pabayaan mag overheat
when you look into the abyss, the abyss looks into you
- Aug 2017
- 49
September 6th, 2017 03:00 PM #23Paano po ba mprevent magoverheat ang car sir? Medyo takot ako sa akyatan eh kasi natatakot ako magoverheat. Di tuloy ako makaakyat sa tagaytay.
September 6th, 2017 03:08 PM #24
September 6th, 2017 03:13 PM #25
Check Radiator. Kung nababawasan ang tubig or kulay kalawang ang tubig pa overhaul mo lang radiator around 700 pesos.
Check Water pump. Youtube mo nalang. heheb
Check engine. Pa check mo sa mechanic mo kung ok pa cylinder head.
Check Thermostat. Kung meron.
sa akin kasi ever since hindi pa nag overheat. I use nga pala antirust coolant mix with distilled water.
Sent from my LG-H870DS using Tsikot Forums mobile app
- Aug 2017
- 49
September 6th, 2017 03:31 PM #26Ah ganun pala. Wala pa kasi ako alam sa sasakyan. Gumagamit lang ako hehe. Salamat sir. Ill take on this po. Ang turo lang kasi sakin ay tingnan kung may tubig.
- Aug 2017
- 49
September 6th, 2017 03:32 PM #27Ah ganun pala. Wala pa kasi ako alam sa sasakyan. Gumagamit lang ako hehe. Salamat sir. Ill take on this po. Ang turo lang kasi sakin ay tingnan kung may tubig.
September 6th, 2017 06:30 PM #28
^ wag basta basta tubig. Dapat gamitan mo na ng premixed coolant para iwas sakit ulo
when you look into the abyss, the abyss looks into youLast edited by baludoy; September 6th, 2017 at 06:35 PM.
- Jul 2009
- 2,618
September 6th, 2017 08:25 PM #29
- Jan 2015
- 3
October 21st, 2017 12:08 AM #30Mga sir any idea about my honda civic 99 vtec ph16 sir look kasi automatic siya pero ang problema is pag nilagay mo sa P R D wala ilaw sa gauge na naka indicate peeo pag nilagay mo sa neutral e nasa P naman nakatapat yun ilaw sa gauge ano po kaya ang gagawin dun
Sent from my A37f using Tsikot Forums mobile app
Daming issue ng SU7:grin:
Xiaomi E-Car
