Results 41 to 50 of 68
February 22nd, 2012 11:38 PM #41
Surprisingly, quite good.
The Alphard is based heavily on the Camry.
Unsurprisingly, during our testing, the Alphard drove just like that... a much heavier Camry V6 with a slightly longer wheelbase.
It was less than a second slower to 100 km/h (faster, in fact, than a V6 Explorer). It was almost as quick through the slaloms. And it braked slightly better... probably because of the better front-rear weight distribution.
I would, without hesitation, take an Alphard out on the racetrack. Good steering, low center of gravity (despite the tall looks, a van like that has all its mechanicals down low, unlike an SUV where the floor, differentials and engine are raised higher off the ground), great brakes.
All you would have to do to make it more potent is to strip the interior and power amenities. It's around 2 tons, that would take it down to around 1.8 tons. Then replace the doors with carbon fiber or even just fiberglass. Add a sports suspension (hoping Camry struts and springs fit) and you're done!
Of course, it would be nice to add a supercharger for more oomph...
February 23rd, 2012 04:24 AM #42
booyah! Alphard V6 drag racing van! it would be faster than an E150 right?
*TS: dapat nag SiR ka nalang. kiddin' :rofl:
Pa-pogiin mo nalang ung RS. buy orig 19" Advan wheels then better looking and grippier tires and a CF chin.
February 23rd, 2012 09:14 AM #43
Naghahanap na ata siya ngayon ng Alphard with carbon fiber doors.
Amusing how i remember the TS started by just looking for a car since ayaw lang niya ata mag commute/taxi after his model shoots or something... ngayon gusto na niya rezing-rezing. Follow what the others said and don't listen to the BS some people tell you of having to mod up, "gauge", etc... There will always be bigger fish in the ocean and if you want to have serious speed, you better have the bakal, skills and wallet to back it up. And do keep it off the streets.
Go with what SiRbossR said. Keep it clean, put nice mags and just keep the car maintained and running well.Last edited by vinj; February 23rd, 2012 at 09:26 AM.
February 23rd, 2012 09:43 AM #44
February 23rd, 2012 10:37 AM #45
February 23rd, 2012 10:55 AM #46
since nasa usapang mods, may plan ako magpalagay ng mga ito sa carens ko.. ask ko lang anu effect nito sa handling? as i recall nasa 20-25t ang kumpletong set na ito...hanapin ko lang pdf file ko..
Kia Rondo 2009 Strut Bar Manufacturers, Suppliers, Exporters, Importers, Wholesalers, Products- Sway bar,rear anti roll bar,strut tower bar,front lower braces,chassis stiffness,
February 23rd, 2012 11:02 AM #47
Less chassis/suspension flexing makes handling better & sharper.
Note: suspension upgrades for better performance usually ends up with (bad) stiff ride which is uncomfortable as daily driver. The key in a daily driven street car is the balance between comfort & performance.Last edited by ghosthunter; February 23rd, 2012 at 11:05 AM.
February 23rd, 2012 11:37 AM #48
On the Carens, I'd go with the rear anti-sway bar and the front four-point. Forget the tower brace, most modern cars don't need it since the strut towers are triangulated into the firewall already.
I don't know if you'll notice the front four-point or tower brace, but you'll definitely notice the rear anti-sway bar on a vehicle as soft as the Carens.
February 23rd, 2012 02:54 PM #49
February 23rd, 2012 03:09 PM #50
bad influence talaga mga kaibigan hehe
ok na sana ang stock na sasakyan pero sasabihin sayo palitan mo ito, palitan mo yan, bili ka ng ganun, bili ka ng ganyan...
before you know it you've withdrawn 50K from your ATM
yung akin naman... you can add the reverse cam and back-up sensor... pero ADAS - I don't think...
All New Toyota Corolla Cross
