Results 1 to 1 of 1
June 19th, 2007 08:37 AM #1
Mga bossing question lang po kung maganda po ba itong subs na ito, newbie lang po kasi ako pagdating sa sound setup. magsstart palang po kasi akong magsetup ng sounds ng auto ko. Meron po kasi sa bahay nito, dala ni erpats galing abroad, gusto ko po sana makatipid so sana eto nalang po gagamitn ko for a subs. eto po specs niya - - - - - - salamat po sa magrereply!
These are the AWESOME Volfenhag ZX4712 Dual Voice Coil Bass Machine Series Subwoofers. Although relatively new to the US, this German made speaker has pleased lots of people and will surely become mainstream here as well. These subs have the following specs: Dual Voice Coil allowing the sub to be run in 2 OHM or 8 OHM mode, Check out the OVER 1 inch surround on these subs for pounding bass without distortion, 1000W MAX power handling with 500W RMS capacity, The subs have a red die cast frame so the speaker holds its shape even when the most demanding bass is applied, They have heavy duty red aluminum cones, the magnet structure is a double stack/vent cooled/fully reinforced/180 OZ. unit, Voice coil is vented for cool operation even during continous play,High temperature Dual four layer 4 OHM voice coil which can run 2 or 8 OHMS Mono or 4 OHMS Stereo, a pair can be hooked to one OHM Mono to high current competition amps!!!, bumped and vented t-yoke, double damper, HD screwed together industrial magnet structur
Update lang nito. I am now decided to get the second hand unit. Napaka smooth pa ng engine, walang...
2016/2017 Isuzu MU-X
