Results 41 to 50 of 62
- Apr 2016
- 6
April 24th, 2016 07:03 AM #41i would recommend growl audio. have one installed yesterday with tv plus. Android pa sya so i just hot spot my phone and use wase there also, and check my farms in Clash of kings pag traffic hehe
- Mar 2004
- 85
July 19th, 2016 06:10 PM #42
- Apr 2014
- 132
July 23rd, 2016 05:55 PM #43nagpa install ako ng abs cbn tv plus sa manila then pagdating ko dito sa davao wala na ng signal. Any recommendation sa mga master? Kailangan ko pa ba mag change ng sim dahil hindi compatible sa location?
- Apr 2010
- 739
July 23rd, 2016 09:25 PM #44It might be that digital tv in PH is not mature yet and hindi pa nagrorollout ng stations outside of Metro Manila, even within MM mahina pa signal in some areas as I've read
Where do you put the antenna? I'm getting a DTV box for a room, and in the process may try DIY'ing it in the car. I am eyeing the "black box" or the RCA DV1402.
Anong power supply ginagamit niyo? I have an unused CDRKing UNIVERSAL CAR ADAPTOR 1800MA adapter, trying to bring down the cost by not having someone install it.
- Jul 2016
- 6
July 25th, 2016 08:21 PM #45
July 26th, 2016 11:05 AM #46
July 26th, 2016 11:06 AM #47
- Apr 2010
- 739
August 1st, 2016 11:14 AM #48I initially got the RCA with the 5v power requirement, gumana saglit yung power adapter ni cdrking then died... pinalitan ko fuse patay pa rin
Inupgrade ko na lang to tv+ since 12v ang power requirement nito. walang tap for positive sa likod ng head unit ko aside from splicing which i didn't do for warranty reasons, so kumuha ako ng cigarette jack splitter then soldered the connections for the barrel jack inside.
August 1st, 2016 04:59 PM #49
sir particle gumamit din po ako ng rca na brand 5 volts. . gumawa lang ako ng wire usb to DC connector. then plug sa usb lighter from cdr king 1 amp.
Sent from my SM-G9287C using Tapatalk
- Apr 2010
- 739
August 2nd, 2016 11:11 AM #50
Latest mileage:
