Results 1 to 7 of 7
June 19th, 2006 09:15 AM #1
newbie po ako.
im planning to setup my sound. ang sabi sa akin. kelangan ko ng :
2 front speaker (2 way 6-2) kicker brand = P4500
1 subwoofer (powered) no need to setup box = P5500
tapos di na raw ikakabit ang rear speaker ko?
ganun ba talaga yun?
eh yun subwoofer nakalagay sa trunk. anong tunog yun kung maririnig ko lang yung sa front speaker?
ok ba yung setup na ito? ok lang ba ang price? thank you in advance sa help
June 19th, 2006 09:47 AM #2
yup pwedeng tanggalin or pwede mo nalang ifade to the front yung staging mo.
June 19th, 2006 11:12 AM #3
pero ano ang mas maganda , tanggalin at palitang ng powered sub o ifade? in terms of sound quality?
what is the difference of the 2 way seps and 3 ways seps?
June 19th, 2006 11:25 PM #4
For sound quality, usually harap lang talaga. Kasi dun ang sound stage. Hindi ka naman nanonood ng concert ng nakatalikod, diba? hehehe.
Pero if you still want rear fill, you can have the rear speakers powered by the head unit then adjust the fader na lang. Wala namang added cost sa pag-set up mo yun. Hindi naman gagalawin na ng installer yun.
Ganyan set up ko sa W123 ngayon.
- Nov 2005
- 81
June 21st, 2006 11:41 PM #5guys makikisakay na rin ako ha,newbie rin kase ako sa sound set up,plano ko ganyan din ang set up,dalawang speaker sa harap,2 high or tweeter tapos subwoofer,pag ganitong set up ba ay kyalangan ko pa ng crossover?tnx in advance
June 22nd, 2006 12:06 AM #6
most new amplifiers have active crossovers built in. yung separates may kasama ng passive crossovers, no worries.
June 22nd, 2006 05:09 AM #7
the use of rear fill will depend on your preferences. used mainly for ambience, some systems will benefit from the use of rear fills while some won't. sometimes, i use rear fills to help lock-in the center image. if you plan to use rear fills, their levels should be barely audible but notably missing when turned off.
Daming issue ng SU7:grin:
Xiaomi E-Car
