Results 1 to 6 of 6
May 26th, 2008 09:18 PM #1
Opinions/suggestions naman pls.
HU - Clarion stock HU
Req - SQ with a little bass when needed
Budget 15-20K
As recommended by several tsikoteers, I visited Jeff Tan of ACA and Benjie of Maspro. Here are their quotations:
ACA ( 15K ) ------------ Maspro (20K)
Sub JBL GTO1202D ---------- 12" Bandpass? woofer with box
custom box sealed
Seps 6.5 JBL GTO6507c ---------- 6.5 Hifonics?
Amp JBL GTS-A604 multi ch? ----------- 2 pcs 2 ch amp korean brand
medyo hindi kasing specific ang details ng Maspro pero i will try to update it when info is available.
basically, ang diff nila is 2x2 ch amp ang sa maspro. 1 daw for the seps and 1 for the subs; sa ACA naman kaya na daw ng amp na JBL ang subs and seps.
Now, will i be satisfied with ACA's setup? or will i suffer an upgrade itch later on. Sayang din naman kasi ung 5K kung ok na din pala and str8 JBL ng ACA.
Another question, ung rear speakers daw ay pwede rin i upgrade sa coaqs later on. Sa maspro sure un e sa ACA kayanin pa ba ng amp niya kung mag coaqs ako later? Malaking diff ba na coaqs din ang rear?
May 26th, 2008 10:26 PM #2
update lang po. audiobahn pala subs ng maspro
eto yata un
ps ty sa pics ni sir C190
May 26th, 2008 10:30 PM #3
kung may chance ka mag audi ng mga systems mas ok para makuha mo yung sounds na gusto mo. then don ka mag decide.
the itch will always be there. hehehe. set a bar kung hanggang san ka lang dahil kung hindi sigurado tuloy-tuloy na yan. hehehe
as for the coax sa rear, kahit wala na lalo SQ ka naman. usually tinatanggal naman to eh, kung hindi man naka fader tapos hu powered lang.
- Jan 2008
- 13
June 2nd, 2008 12:42 PM #4Straight JBL set up ka na lang. Kaya ng 4ch amp mo yan. Ung 2 channels naka bridge tapos ung 2 for the seps. Di mo na kelangan upgrade ng amp nun. Ok din ung sealed box kasi mas maliit ung kainin na space.
June 2nd, 2008 08:13 PM #5
thanks po. I just had ACA's setup altho hindi pa finished and box ko. btw ported box na ang napagawa ko. Is installing rear coaqs worth it? if not, ok na pala set up ko, just waiting na lang sa arrival ng pioneer HU ko na DVD and touch screen.
June 2nd, 2008 09:15 PM #6
^^ kung may lagi ka sakay sa likod then oo ok ang rear coax... kung SQ naman... ok lang yung walang rear lalo na kung lagi ka magisa or 2 lang lagi sakay.
if you decide to hook it up rear coax, let it be powered by the HU
Monk-owned R53
