Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    May 2004
    trup, depende sa amp. some amp require 1 set of rca(input) kahit mono ang output. some uses either the left or the right RCA channel. this is according to one kac regular DIY.
    Quote Originally Posted by niwde11 View Post
    edwin, sa hu kse galing yun 1 rca, subwoofer output talaga sya. ang problem ko pano ko i-connect yung 1 rca sa +/- ng subs, plan ko 1 sub lang naman. below yung rear view, the 2 yellow rca para sa aux, yung blue rca ang subwooofer output. yung rca's for the front and rear amp nasa other wiring harness
    May 2004
    trup, afaik, pra g rca out (wheter mono or stereo) e di kaya mag drive ng isang subwoofer. i think even a midrage. kasi low-level signal ang rca while high level signal ang speaker wires, you still need an amp para maidrive ang subwoofer coming from an rca output.
    Jan 2004
    Tama po ito.
    Trup, your HU has a subwoofer RCA out because it may have a built in crossover/low pass filter that only allows "subwoofer" frequencies to pass through that RCA line. Its output is unamplified, and thus requires an amplifier, that in turn powers a subwoofer. The amp has the +/- speaker outputs.
    uber, for the new hilux give this a try. DLS 6" subs (pic shown installed on a hilux 05' model.) it comes with its own amp.
subwoofer
