Results 41 to 50 of 66
October 8th, 2003 02:12 PM #41
Galing po sa customs. Eto daw yung mga lumusot sa inventory listings nila. I was supposed to get 3 7450 units kaso naunahan na ako sa 2.
October 8th, 2003 02:24 PM #42Originally posted by Ungas
Yung demo mode ba yung pinipindot yung function switch when the radio is off?
October 8th, 2003 07:56 PM #45
Alternating lights adjusted! :D
Pag pinindot yung 6 demo function, may lumalabas nga yung reverse feature press 5. Followed the instructions. Nawala nga after waiting for a couple of minutes.
But when I turn the radio off and press 6 again to check, reverse feature is still "off" same as before. Though the display did not change or reversed its display. Weird?
October 8th, 2003 09:05 PM #46
Follow up question: (Pasensya na bagito kasi pag dating sa sounds)
-Pressing the Audio button for 5 secs or more, may lumalabas na pang fine-adjust ng equalizer curve. There are some choices 2N-1N-1W-2W for Low: 40-80-100-160 Hz, Mid: 200-500-1k-2k Hz, High: 3.15k-8k-10k-12.5k Hz. What's the difference if all bands were adjusted to 2W?
October 8th, 2003 10:47 PM #47
hinde ko na nakakalikot yan ah..hehehehe
sama mo naman ako sa customs minsan.haha.. anug mura naman nyan
October 9th, 2003 12:47 AM #48Originally posted by Ungas
You get to choose if you want to boost a narrow or wide range of frequencies.
October 9th, 2003 11:07 AM #49
odell::: Di naman ako pumupunta dun, the guy usually calls me then delivers the package straight to my doorsteps. Dun ko lang sya babayaran pag gusto ko yung unit.
Beefy::: What's the stock settings? Kinalikot ko kasi di ko na maalala yung oe setings, hehehe. Mahina pa pandinig ko sa mga ganyan setups. I don't see any difference with 1N and 2W.
October 9th, 2003 01:13 PM #50
Di ko alam stock setting.. for sure may madidinig ka na change as long as wala sa -1,0 or +1 yung EQ...
Mandatory na ba ang PMVIC or pwede pa rin emissions lang?
LTO car registration and late registration fees
