Results 1 to 9 of 9
September 14th, 2007 07:56 PM #1
I was wondering kung pwede i-series ang 2 relay. Masusunog ba electrical pag ganun? Kung hindi, lalakas ba ang output o parehas lang sa 1 relay? TY.
September 14th, 2007 08:02 PM #2
ang relay po ay parang switch lang po, parang circuit breaker, kaya useless to series it naman.. unless may special purpose...
if you just need a bigger ampherage, just buy high-ampherage relay..
September 15th, 2007 07:39 AM #3
Ah ganun. I always thought na pampalakas ng current ang relay. Dati kasi nagpalit ako ng stock na busina without adding a relay, ayun mahina. Nung dinala ko sa electrician nilagyan niya ng relay para raw lumakas.
September 15th, 2007 09:08 AM #4
September 17th, 2007 03:42 AM #6
a relay is like a secondary switch..pag ni on mo, say, your headlights, mag-o-on ang relay which switches on and then draws its power from a live wire(from battery) to the headlights...parang ang labo ng post ko..antok na
September 17th, 2007 09:39 AM #7
Agree that it is a switch. But being one, it has an operating current rating. This means that if you put one in series with the other, then you are not increasing your current(A) capacity, probably defeating your purpose of using 2 relays.
It is better if you place one in parallel with the other. Although this is not ideally 'desirable' since one will switch faster by a few msec than the other.... In general, though, it will work with your application.
However, I suggest that you just buy a relay with a higher current rating.
3808:fish:
- Oct 2006
- 99
September 21st, 2007 10:17 AM #8relay is just an electrical switch sir, kya po lumakas yung busina mo after lagyan ng relay is because parang nkdirect connected yung busina mo sa battery, and yung lumang wiring eh ginamit nalng for switching the relay. kasi po pag-walang relay yung current going to your horn eh parang ng-around the world pa before it reaches the horn terminal, and wires have resistance and it is directly proportional sa length ng wires so paghumaba ang wire taas ang resistance then pag-mataas ang resistance mababa ang current...
