Results 11 to 18 of 18
January 22nd, 2006 05:52 AM #11Originally Posted by FXT
January 22nd, 2006 06:25 AM #12
if you're running 300W, very unlikely ho na clipping yan, unless you have a defective amp. tsaka yung sound ho ng clipping is not "popping", it's usually "distorted" or "breaking-up" sounds.
January 22nd, 2006 06:50 AM #13
....hmmmm, madala na nga sa shop before i invest in a better amp. tnx FXT for the input.
....what if i ditch the amp right now (til i get a better one), and let my HU (5750mp) do the work. mabibitin lang kaya ako sa tunog?Last edited by scarab; January 22nd, 2006 at 08:18 AM.
January 22nd, 2006 04:25 PM #14
scarab: re: grounding - it doesn't need to be bare metal, even a painted surface will do... make sure that its clean.
Don't ditch the amp, bitin na bitin yan, try taking off the tweeters and see how it sounds, if it doesn't have any problems then its not your amps, it could be the wiring. Also check the gain settings it might be too high. Good luck
January 22nd, 2006 04:34 PM #15
try to swap a good amp to yours. sabi mo nakatambak na yun amp mo so i suppose i was not use for a lng time. my best bet is that there are some leaking capacitors in the amp.
January 24th, 2006 12:56 AM #16
....actually im in the hunt for a good 2nd hand SQ amp kaso sobrang limited budge ko. anywayz, someone told me a bad amp may ruin my seps; is it also true that it may also eventually damage my HU? medyo dun ako natakot eh.
January 26th, 2006 11:39 PM #17
....mga bro! ganun pa rin after switching the tweets nag-pa-pop pa rin sa left side (so di tweets problema). minsan biglang lalakas pa tunog.
....checked the RCA connectors, ok naman. wirings seem to be clean and connected well sa passive xover. sa amp na kaya yun?
....arggghh! sarap pa naman pakinggan yung bagong CD ni anton ramos (sisters of the sun) pag SQ kaso that sudden popping is annoying!
January 26th, 2006 11:44 PM #18
Its either the tweets or the Amp. Try to borrow an amplifier from a friend and test it.
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
