Results 1 to 9 of 9
June 5th, 2006 09:03 AM #1
Guys, question lang po...
I'm Planning to buy this HU for my AUV, tanong ko lang po, pwede ba ako magkabit ng subs kahit walang additional amp? kakayanin na ba ng HU na to ipower yung subs? kasi based sa specs ng HU, may two way crossover na toh... yung seps ko OEM lang din... very tight budget kasi eh... gsto ko lang maimprove ung sound ng tsikot ko and gsto ko lng may bass ng konti... ok na ba if i'll buy a sub tpos ilalagay sa kaha... iwas din kasi ako magbutas eh may space naman sa likod ng auv... saang reliable source ang pinakamura yung model na to and at the same time pakabit narin... mga how much po kaya ung headunit? sory po madaming tanong... newbie lng po... thanks po mga sir!
June 5th, 2006 12:12 PM #2
magiging sobrang underpowered yung sub. if you dont want to install an amp for the sub, your best bet would just to have decent 6x9 speakers installed for your bass requirements. sayang kasi yung sub pag hindi powered by an external amp. di lalabas yung potential niya, and sobrang bitin yung oompf or thump ng bass.
but that's just me.
June 5th, 2006 02:37 PM #3
Sir SSaloon,
ok parin ba sound quality kahit na OEM lng ung ibang speakers? bali po may 6 speakers ung auv, 2 sa rear, 2 sa front, and 2 front tweeters dun.. lahat po ay oem... will adding a 10" sub and an amp to power it suffice my needs? anu po mga brand ng sub and amps ang kakasya sa 8-10k budget? including na po dun sana ung labor and wiring... btw, anu po coment nyo sa HU na target ko? thanks!!!
June 5th, 2006 04:23 PM #4
ok na rin yung HU. iPOD ready na ata. go targa and a v12/fenton amp. pasok sa budget yan.
June 5th, 2006 09:20 PM #5
yes it has a two way crossover to seperate the frequencies to LP and HP. but you need an amp to make use of this feature.
V12 na four channel can power both your front and subs.
June 19th, 2006 12:41 PM #7
eh kung yung sub po ay built in powered na. meron po bang ganun? para di na kailagan ng amp?
yung kicker na seps (2 way) maganda ba yun?
June 19th, 2006 05:18 PM #8
yup, meron mga active subs ang infiniti and blaupunkt. pwede na hindi gumamit ng external amplifier.
June 19th, 2006 06:04 PM #9
quality of sound? which is better powered sub or with amp? with regards to the differences, is it negligible? o halata ang pinag-kaiba.
Monk-owned R53
