Results 1 to 6 of 6
- Jul 2010
- 1
November 17th, 2010 01:01 PM #1good day to all, plan ko sana mag upgrade ng sounds kaso wala pa ko budget ng isang buhos, like buying amps and sub, based sa pagbabasa ko dito sa forum puede naman daw unti unti like separates muna, then amp, then sub... hope the audio experts here can help me... thanks in advance
car is corolla big body xe, current setup ko is pioneer HU with sub out, 3 preouts, plus a pair of 2-way speakers sa harap and a pair of 2-way speakers sa likod, brand is pioneer din.
a. pag nag separates ba ko ibig sabihin yung pioneer speakers ko kelangan palitan din ng bagong set, or i can retain them para di naman sayang hehe
b. puede ba ko mag separates lang muna? or separates and ampli? then to follow na lang yung sub? medyo di din kasi ako mahilig dun sa sobrang bass, more off yung clarity yung habol ko, pero syempre pag mga RnB sana may bass din na mas maganda sa current setup ko.
c. can you guys recommend a bang for the buck na separates and ampli?
thanks in advance
November 17th, 2010 06:49 PM #2
a. yes sir. kailangan alisin yung pioneer sa harap kasi dun ilalagay yung separates. di naman masasayang kasi pwede mo naman ibenta yan. yung sa likod, pwede mo naman iretain. mas ok kung yung HU mo ay may fader para pwede mo mahinaan yung likod.
b. yes. pwede rin kahit by phase ang upgrade. seps or seps+amp muna, then sub.
c. depende sa budget mo sir. contact mo yung candy shop or araneta car accessories.
robot.sonic
November 23rd, 2010 03:07 AM #3
Hehe.. gayahin ko sagot si robot sonic joke..
1. You normally replace the front with the separates of your choice. Although suggestion ni robot.sonic na iretain nalang yun likod and then fade it, I'd rather opt to sell the rear ones too.
Since nasa driver's seat ka naman, your aim is to really make the soundstage be at the front (hence the fade). For example, you're hearing a live acoustic session. Yun music galing sa harap, hindi sa sides or sa likod (or surround sound in that effect).
2. Pwede. With regards to your seps, your HU can power it for the meantime if you're still haven't bought an amp. Of course, kung nasa "mid to high" end na mga seps mo, you're robbing yourself of the needed power.
3. Yep, as robot.sonic says, depende yan sa budget mo, sir.
If you're still starting out, Kicker is one of those bang-per-buck manufacturers. Add a bit more, and you can get the brand names -- Focal and DLS (biased ako sa dalawa eh since nakadalawang Focal na ako..). Other well-known brand names are Morel, Coral, MB Quartz (dati maganda eh, ewan nalang ngayon), Cadence, etc.
- Sep 2007
- 34
December 25th, 2010 02:45 PM #4Hi Sirs,
I recently upgraded to DLS B6A speakers. Is it best to still have this connected to an amplier or is the HU enough? What amplifier do you recommend? My HU is a JVC KD-BT22.
Thanks
December 25th, 2010 02:52 PM #5
January 5th, 2011 12:46 AM #6
Monk-owned R53
