Results 1 to 8 of 8
Unregistered user
- Jun 2003
- 1,122
August 25th, 2003 02:37 AM #1i plan to do a low budget set up composing of targa speakers... the speaker hole on the door as ive measured is only 4" it is a boxtype pajero btw
i already have a 4ch tekline amp with an old sony hu 35 watts
i plan to put
a set of 4" targa seps up front (tweets under the dash and seps at doors)
a pair of 4" targa coaxials at the 2nd row doors
a pair of 6x9s way back (behind the jump seats)
an eight" active sub (stealth by targa)
my questions:
i already have a tekline 4ch amp what should i do? is this correct?
-hook the separates on ch1.ch2 and hook the 6x9s on chan 3, ch4
-coaxials will pe powered by the HU
then attach the active sub on the out of the hu
___________________________________________
2) can i hook 2 sets of separates on the same chan?
if this is possible how do i do it? screw both wires on the same out of the amplifier? or join the 2 positive and 2 negs. of the spaker before hooking it to the amp?
3) can i hook the 6x9 together with a 4" subwoofer?
(if this is possible i plan to scratch the coaxials and get a pair of 4" subs instead for the rear doors
4)how do i adjust the gain and freq of the amplifier?
5) is there a website that can teach idoits like me to do a complete sound set up
sorry for the heaps of questions im just a newbie w regards to setting up sounds hope you guys will be kind enough to help....
- Jan 1970
- 25
August 25th, 2003 10:14 AM #2I recommend that you let the HU power the 6x9s... and let ch1 & ch2 power the front seps, ch3 & ch4 for the subs.
do not power the sub from the HU... dapat sa amp. baka di rin tumunog yan... or basag ang tunog.
- Jan 1970
- 25
August 25th, 2003 10:16 AM #3oh... active pala yung sub mo... hehehe... kala ko hindi, eh. mali basa ko... soweeee.
oo, tama balak mong wiring config.
August 25th, 2003 10:49 AM #4
Active means may bulit in amp ?? If yun ay bulit in , yung amp mo ay sa mga mids n seps mo na lang .
August 25th, 2003 11:44 AM #5
as long as your tekline amp has enough wattage to power the four channels you'll be ok. typically the self-powered sub boxes have amps that match the woofer perfectly.
only one question: bakit 8-inch, when you have a lot of room in the pajero? 8-inchers really don't give you really powerful bass response, if that's what you're looking for. i'd suggest a single 12" instead.
August 25th, 2003 12:03 PM #6
yup, i agree with M54. 8"ers aren't too powerful (unless you're talkin about L7s), tapos powered sub vs. sub-powered-w-external-amp. anyhow, your connections are ok. test mo yung sub kung ok na rin sa yo good luck.
Unregistered user
- Jun 2003
- 1,122
August 27th, 2003 01:32 AM #7na audition ko na sa dai ichi sa megamall ayos na sa akin yun stealth na active sub
di naman spl habol ko e basta mas maganda lang sa stock
and talagang low budget lang ako happy na ako dun
i have another question: if an amplifier is 4 chan and rated at 200 watts it meand 50 per channel?
Latest mileage:
