Results 21 to 29 of 29
- 229
November 8th, 2002 01:33 PM #21IMm29,
Dude, the KAC Grand EB will be tomorrow na1 if you can, drop by the fort na lang tom para mas maramika maaudition.:D:D
- 159
- 69
November 9th, 2002 09:44 AM #23216 din gamit ko.. dati may time na nagkaroon ng hiss sa tweets..
sabi sa akin.. lower ko yung trebble sa HU.. tapos i did.. nawala nga..
then adjust sa amp ko..
tama si leon, madalas sa recording nagkakaroon ng ganitong hiss.. madalas pa sa fm stations..
imm29: when you turn off your HPF your using the full range of the seps.. nasubukan ko na yan dati para i could get the midbass that i want.. pero ang naging problema kapag nilalakasan ko volume.. nababasag yung tunog.. so la akong magagawa kaya about 80hz lang ang ibaba ng HPF ko kaya hangang dito nalang cutoff ng seps ko..
guys see you there later! :D
November 10th, 2002 06:50 PM #24
Sorry, d na ako nakapag-reply. Anyway, hope your Grand EB went well.
geo626 and leon275,
let me see if i get this right...so the solution to enjoying your 216 is to use 80hz of the HPF and have a 60wx2 amp drive them? bass response won't be as good, but hindi na mabababasag ang tunog. tama ba ang assumption ko?
- 69
November 10th, 2002 06:56 PM #25bitin sa midbass.. pero ganun talaga e..
di ko pa nasubukan if i use xover para mas mababa..
yep hindi nababasag yung tunog.. even if i use my full volume.. basta naka zero ang fader..
unlike nung nagfull range ako.. about 28 -30 ng volume.. it started clipping..
- 229
November 11th, 2002 04:51 PM #27Originally Posted by IMm29
- 69
UK, Oz-wide JB74 fuel pump recall. Check Suzuki Ph for VINs affected. Sent from my SM-S901E...
Suzuki JIMNY [merged threads]
