Results 1 to 5 of 5
December 17th, 2005 12:16 AM #1
hi
just bought a "SUPER" brand LCD Tv from Hongkong. It worked fine there when tested. I know they are on the PAL format. TV's system setting was on "I".
Now i cannot choose the correct system setup to receive Phil TV signals. from the choices of M/N, L, I, DK, BG; can anyone please advise the correct setting for NTSC/ Phil TV signal sytem setting. I did the trial&error thing to no success.
Thanks
December 17th, 2005 01:20 AM #2
hmm if you tried every setting and didnt work..then it isnt compatible to our tv sytem..years ago,i bought a small casio tv from hk also..it worked fine here..problem is i couldnt find the tv itself anymore hehe..
BANNED BANNED BANNED
- 3,790
December 17th, 2005 02:46 AM #3Originally Posted by kurt
Anu ba ibig sabihin nuon? wala ba sa manual?
Did the unit say it was multi-system?
At worst i-rereprogram yan...they'd replace the crystal in the RF yata
December 17th, 2005 03:20 AM #4
select lang ntsc yung super 8" na punurchase ko year ago ganun din walang ma recieve na local network..ginabitan ko ng yogi antenna ayun nagka channel pero 23/7/13 lang disturted pa, sa cable di rin compatible alang audio...pina change items ko nalang within a wk..pero sa A/V input walang problema ok na ok..>>
December 17th, 2005 11:36 AM #5
thanks for the replies
I thought M was the code for NTSC, but researching wikipedia, ther is also a PAL-M.
i think i figured it out, the manual was of little help, but i noticed a small sticker at the back saying syestem:PAL then NTSC (video only). so i think its not really meant for NTSC Phil TV signal. It can only receieve NTSC from the AV in
using the A/V in jack, plug it into the TV got me the same signal as our cableTV.
Though choosing M/N setting got me all the UHF channels, and i think i also got a poor signal of ch2 and ch5.
Follow up question; is there a HUD or radio unit that has a TV tuner on it. please advise its make and possible price
thanks
Monk-owned R53
