Results 11 to 17 of 17
December 16th, 2006 08:21 AM #11
it does not matter if may capacitor ka.
check mo karga ng alternator and change to a bigger battery or add another one for your sounds.
Tsikot Member Rank 4
- Jun 2006
- 2,605
December 16th, 2006 01:16 PM #12Tama ba intindi ko?
1. Car running on sound system, lights and aircon then it died?
2. volt meter reads 13 volts no acc and 12 volts with acc on? How many volts do you get when acc on and reving the engine?
I'm no expert and its been years since I was into car audio so I may have forgoten somethings. But here is my opinon.
1. If you are getting at 12 volts then you should have sufficent voltage to run the car. Cars are designed to use 12 volts. Your battery is 12 volts. When reving the engine you should be getting up to 14.4 volts courtesy of the alternator.
2. Check how many amps your system and acc draws and how many amps your alternator can supply. Baka overloaded ang alternator. Although I kinda doubt it, unless you are running a very high wattage amps.
3. Get you battery and alterantor checked baka mahina na.
4. Check for loose ground cable sa battery and pa check mo rin kung may ground yung kotse.
5. IMO a 2nd battery will not help you unless you listen to your system with the engine off.
6. A larger alternator will help pero gatos cguro last resort.
- Nov 2006
- 122
December 18th, 2006 10:10 AM #13hello mga expert thanks sa lahat ng nagreply sad to say di ko pa rin napapacheck ung auto ko kc sobra busy last weekend due to christmas season.Ang ginagawa ko na lang pag on ac off ang sounds ko or vice versa,sa gabi di na ko use foglight unless madilim tlga daan pero saglit lang off ko ulit.
Otep- ok namn ac ko pag on,di namn ganun kalaki kain ng volts basta wag lang sasabayan ng mlakas na sounds at headlight sa gabi bumababa ang volts reading.
Userfriendly-di sya namamatay while im running but what happened is ng off ko when i drop by to a store ayaw na sya magstart ulit click na lang kaya tinulak ayun nagstart twice na un nangyayari sakin sa gabi. 12.8 voltmeter reading ko reviving engine or highway driving using headlight and a/c on and off sounds.pagtraffic naku 12volts na lang at pag on pa sounds and foglight bagsak na sa 11.7 voltreading.that was base on my voltmeter na hiniram ko na sinasaksak lang sa lighter plug.
Power eagle- magkano kaya alternator jan sa evangelista or banaue just in case magupgrade ako.Actualy di ko sure kung ano bibilhin ko kung surplus or recondition kasi mahal ang brand new di kaya ng budget lalo na now dami gastos papasko hehe..
Additional question lang po mga henyo there na nkaset up audio, nagupgrade po ba kayo ng alternator nyo?thanks God bless
December 19th, 2006 08:06 PM #14
pag start mo nag cclick or nag reredondo pa?
kung click more or less sa batt na yan...
try mo muna humiram ng ibang batt sa mga friend mo. para ma isolate mo lang.
December 19th, 2006 08:13 PM #15
Ano ang set up mo? I just run a single amp, a pair of seps and a 12" SVC sub on my rig. Stock Mitsu amp, hindi naman natatalo.
December 19th, 2006 08:27 PM #16
When I had to put on the big guns (sounds) on my '95 Pajero, I changed my battery to 13 plates just to be sure then placed a digital voltage meter to monitor any drop sa kuryentye.
Used RF 800 Power Series Amps to drive the Kicker 12incher only. The soundstream was for the DLS MS6 Seps. Mind you the capacitor is just for the extra whooomp, not reserve power. It can only do so much.
So I guess you just have to double check the battery. Have the alternator checked for efficiency.
my 2 cents.
- Nov 2006
- 122
January 4th, 2007 09:44 AM #17happy new year!!!
mga sir update ko lang po kyo sa problem ko.Ok na po auto ko what i did is nagpalit po ko ng alternator na medyo mataas ampere,imagine 50amps lang pla ung stock ko e loaded ko sa acc.80amps ung pinalit ko sa evangelista surplus japan with 2 months warranty 1.5k lang kasama na kabit.Muntik na ko bumigay sa 3.5k na alternator na recon e yun pla pinipinturahan lang yun para mukhang bago tapos lalagyan ng plastic buti na lang my tsikoteers..the best tlga mga tao dito.Thanks po sa lahat ng nagreply.Ngayon kahit sabay sabay ung gamit ko ng load sa gabi ok lang di na talo sa karga pero di ko ra rin pnagsasabay sabay lahat unless kailangan tlga mahirap na abusuhin dba ung tamang gamit lang.salamat po ulit.
