Results 21 to 22 of 22
- Apr 2005
- 26
May 4th, 2005 05:56 PM #21mahirap pala na bisyo eto. hehehehe
keep the suggestions/comments pouring sirs. thanks!
- Apr 2005
- 26
May 4th, 2005 09:39 PM #22sirs, pwede na po kaya eto
THUNDER AUDIO
D-Class Amplifier
1x300 Wrms * 4ohms
1x400 Wrms * 2ohms
1x800 Wrms * 1ohm
Ultra-fi Mosfets
SPC Simpatica Coil Design
Fully Adj Accu-Crossovers
PWM Mosfet power supply
Line Output for Daisy Chaining
Variable Base Equalization 0db-18db
Sub-sonic Filter 15Hz-35Hz
4 4 Guage power connector
Additional High Speed Mosfet Output Devices
Maxi-Fuse
Base Remote
Variable Level 9v-.2V
Phase 0-180
Variable Low Pass 35Hs-250Hz
thank you its good naka timing chain pala. yan din concerns ko sa used car like sa dati kong...
