Results 1 to 4 of 4
November 21st, 2008 12:42 PM #1
I have two TS-W3004spl(Premier®). I Need a Amplifier to power speaker. Can someone tell me what would work the best, and what would specs of amplifier be? Any and all advice/help appreciated.
Speaker
Specifications :
Watts MAX. Music Power 3000 Watts.
Watts Nominal Power Handling 1000 Watts.
Frequency Response 18Hz ~ 700Hz.
Sensitivity 89dB.
Size 12" SPL Component Subwoofer
Ohm Rating DVC (Dual 4 Ohm Coils)...
- Nov 2008
- 123
November 21st, 2008 07:31 PM #2
- Nov 2008
- 123
November 22nd, 2008 04:49 AM #3Hi, try this site..maganda to..makikita mo ang amp na gusto mo..at isa pa makikita mo rin ang loob sa amplifier..(www ) (realmofexcursion) (com) to go "COMPONENTS" then click "AMP GUT" then choose and explore! Good luck!
November 22nd, 2008 07:42 AM #4
If your sub's have Dual Voice Coil (DVC) then you are in the right track for more options on wiring your system and you can let add more sub's (series wiring) or draw additional power from your amp. If you wired w/ parallel on your DVC your amplifier can give you the maximum output.
Best match. Find out the power range (watts RMS) of your sub's then match an amplifier RMS wattage rating to the upper range of your subwoofer. You just have to make choice if, Mono, 2 or 4 channel amp you want to use. If you choice are 2 or 4 channel make sure it has a Low Pass (LP), High Pass (HP) filters or sometimes called "Variable" or "Selectable".
If you need assistance how to wired your system or how to make choices or options for your future expantion before it drains your wallet PM me.
also... mabenta Suzuki sa India
Car Sales Data (2023)
