Results 21 to 21 of 21
February 21st, 2008 03:06 AM #21
+1 po..
www.crutchfield.com
Q: If I put my subwoofer box in the trunk, will I be able to hear the bass?
A: Absolutely. The only situation that might prevent you from hearing bass from a trunk-mounted box would be if your trunk is sealed and soundproofed. Usually, bass travels easily through the materials separating the trunk from the passenger compartment. If you think you're missing out on bass because your seatback and rear deck material are blocking the sound waves, you can alleviate the problem by punching a few small holes in the rear deck and covering it with an acoustically transparent material.
more info...
http://www.installer.com/tech/aiming.html
http://www.installer.com/tech/aiming2.html
