Results 11 to 19 of 19
February 26th, 2007 09:56 PM #11
If the battery is rated 40AH and your load is 5 amperes, you will have an 8hours play time before the battery is totally discharged. To be safe, you can have a playtime of 4 hours to reserve enough AH to start the engine. Remaining available Ampere-Hour rating of the battery decreases as it becomes older.
Battery is considered totally discharged if the terminal voltage falls down to 10.5 Volts.
February 27th, 2007 10:33 AM #12Originally Posted by GLImamasan
Good Read about batteries (Deep Cycle and Normal Lead-Acid car batteries
http://www.uuhome.de/william.darden/
http://auto.howstuffworks.com/question219.htm
Basically the biggest difference is that a Deep Cycle Battery is designed to withstand several hundred Discharge/Recharge Cycles that a Normal Lead-Acid can't do.
I wouldn't recommend listening to the radio with your engine off using a normal battery, it would be a hassle not being able to start your car even tho you have jumper cables. Well if your battery is still under warranty you could always call up motolite and have them deliver a warranty replacement or a new battery
February 27th, 2007 11:50 AM #13
February 27th, 2007 02:18 PM #14
OT: para makatipid ako (sa gas and sa battery as well), I just bring a good book to read o kaya PSP na lang.
February 27th, 2007 03:40 PM #15
February 27th, 2007 03:47 PM #16
would installing a capacitor for your sound system have an effect on running your sounds while the engine is off? I currently have a 1-farad installed and I can run my sounds at around an hour to one hour and a half. thanks. I;m just a newbie here. =)
February 27th, 2007 04:19 PM #17Originally Posted by mbeige
http://www.optimabatteries.com/publi...eep_cycle.html
Originally Posted by raphael_allen
February 28th, 2007 01:37 AM #18
March 13th, 2007 12:37 AM #19
Say you want to use your car setup like a open trunk party or picnic while engine is off.. can you use a portable 12V battery charger and charge your battery? of course the portable charger need 220V supply. Will it work? it wont damage any electrical component of the car? TIA
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
