Results 21 to 27 of 27
April 22nd, 2005 09:20 PM #21
personally a vacuum guage is simpler to install and use.
btw, autogauge vacuum gauge selling for P1000 at the transportshow.
- May 2004
- 84
April 23rd, 2005 03:42 AM #22sir kinyo, thanks! honestly i really wanted to build it by myself din.... i just want to see how you flushed the led or how you made the display.... madali lang pala e... i can add another 10 led's if i want to... kung medyo maarte... dag dag IC nga lang... =)
Tsikot Member Rank 4
- 2,716
- 2,716
- May 2004
- 84
April 27th, 2005 05:47 AM #25astig!
ser, question uli...yung green wire ba go to your MAP? secondly, yung potentiometer na ginamit mo yung maliit lang? (kailangan ng precision screw to adjust)... lastly, san sa MAP nyo kinabit yung input sa electronic vacuum gauge?
pasensya na ser at maraming tanong
- 2,716
April 27th, 2005 11:26 PM #26yes, the green wire is the input signal for the circuit, hence it connects to the output of the MAP sensor ... opo, 100k trimpot lang yung ginamit ko, nakatayo sa board kaya topview lang ang kita sa pic ... in my car, the MAP sensor have 3 wires, namely, +5V, gnd, and output ... iirc the output signal is on the grn/wht wire ... you will have to find the output signal for your car (which are likely to have different wire colors if your car is not a civic), but it wont hurt anything if you simply try connecting one at a time to each of the 3 wires using a needle and find which one works ... be careful with the 5-volt line because it is coming from the ECU, shorting it to ground would kill the ECU!
- May 2004
- 84
