Results 1 to 7 of 7
April 25th, 2007 10:31 AM #1
Is it possible to prevent/disable the car's antenna from rising from its 'hole' when i'm only playing CD and not using the radio tuner at all? And only rise when radio function is selected?
April 25th, 2007 10:41 AM #2
You can put a manual switch between the radio and antenna so you can cut current to the antenna when you are playing CD's.
In essence you will fool the antenna into thinking that the HU is off.
April 25th, 2007 10:57 AM #4
DIY i presume kung maalam ka sa wiring ng audio system mo. But i think any electrical shop can handle that. I'll just have Rey's Electrical do it...kaya lang antay na lang ako ng isasabay na ipapagawa.
I was actually hoping na may some sort of jumper/swirch settings i can manipulate sa system...anyway.. thanks.
April 25th, 2007 11:34 AM #5
Some HUs have this feature. But most newer HUs now have removed that feature since most car antennas now are either fixed type or printed type.
April 25th, 2007 01:12 PM #6
its not as easy as just putting a switch between the antenna and the HU. may modification pa na gagawin sa switching ng antenna. there are different types of antenna circuits. just make sure na trarabaho ang antenna after the modification.
- May 2006
- 78
April 28th, 2007 02:01 PM #7Tanggalin mo HU sa dashboard. Sa rear panel ng HU mo, may wire yun na naka-indicate Power antenna. Pag naka ON HU ko dati, tataas yung antenna, so what I did is put a toggle switch betwwen the wire sa antenna ko and HU. Ngayon OK na, kahit naka CD ako di tataas ang antenna ko.
Try mo.
