Results 1 to 7 of 7
- Aug 2008
- 142
March 28th, 2019 07:43 PM #1The power telescoping antenna on my 2008 Ford Escape has stopped working. A replacement assembly costs 16k From Ford. Is there any shop that can convert power antenna to fixed mast?
March 28th, 2019 08:29 PM #2
Putol lang yung geared nylon/plastic string nyan. Kayang-kaya nila palitan yun sa banawe. Magtanong ka lang dun sino nagrerepair ng power antenna. No need to replace the whole assembly.
- Sep 2008
- 587
March 28th, 2019 08:47 PM #3I had that white string replaced before in my ride but it did not last long. I decided to buy a generic power antenna in lazada for less than 1K and installed it if you opt for the power antenna. I was looking also for a manual hirschman antenna, but it cost about 3K +, thus I decided to get the automatic generic antenna instead.
- Aug 2008
- 142
March 29th, 2019 06:22 PM #5I actually shipped a replacement mast w string that I had installed by an auto accs shop. Unfortunately a few days after they installed it the motor failed. So I am looking for a fixed antenna replacement. I bought one from Amazon but it is meant to replace the OEM antenna of the USDM Ford Escape wc uses a fixed antenna to begin with...the Escape here has no threaded receptacle to accept fixed antenna so kailangan replacement kit talaga.
- Oct 2009
- 2,271
March 30th, 2019 02:51 PM #6sa vti ko dati nagsawa din ako kapapalit ng string gear cable..kaya hindi ko na pinataas pa ung antena at bumili nalang ako ng active antena.indoor antena na electronic.
March 30th, 2019 04:54 PM #7
The key to power antennas is to not let it get caught in anything. Once that happens, thats when the problems starts.
Besides the HU power i also installed an up-down switch so i can manually lower the antenna.
