Results 11 to 15 of 15
March 17th, 2009 05:16 PM #11
March 18th, 2009 06:37 AM #12
You are all set and ready to fire up. Your 2 channel amp gives you two output but that doesnt mean you have to connect two subwoofers. You can connect 1, 2 or even 4, you just need to be aware of the impedance and the load capability of your amp. So look at your amp if stable down to 2 ohms. Now, when it say's 2 ohms stable on your amp it referring only to the minimum impedance it can handle in 2 channel mode(not bridged) but mono. I believe your subs wired in parallel, if it is, your impedance are low meaning your 2 ohms amp will give you more power because less resistance or load to the amp. The more power it produces, the louder the music play's.
If you want to tune your system, I can help you. Whenever you are ready PM me.
March 18th, 2009 01:41 PM #13
The amp naman po is 2 ohm stable so i think it can drive the subs.
Eto po specs ng amp for subs na bibilhin ko.
MRV-F706 3200 watts MAX POWER
4 / 3 / 2 CHANNEL CONFIGURATION POSSIBLE
2 OHMS STABLE & POSSIBLE *TRI-MODE CONNECTION
800W PER CHANNEL MAX * 0.5THD CONTINUOUS OUTPUT
ADJUSTABLE SUB X-OVER FREQUENCY 40~150Hz
HIGH CURRENT DISCREET OUTPUT DEVICES
ADJUSTABLE RCA LEVEL OUTPUT
HIGH POWER MOSFET POWER SUPPLY
INPUT GROUND ISOLATION NOISE FILTER CIRCUIT
*TRI-MODE: 1 SUB + 1 SET SEPARATES / SPEAKERS
ULTRA STABLE PWM (PULSE WIDTH MODULATED) PWR SUPPLY
HIGH EFFICIENCY MOSFET SWITCHING DEVICES
TRANSIENT NOISE FILTER/ MUTING
EASY ACCESS FRONT CONTROL
2/3/4 WAY AMPLIFIER WITH EXTRA RCA OUT FOR ADDITIONAL AMPLIFIER ATTACHMENT
THERMAL AND SPEAKER SHORT CIRCUIT PROTECTION
BUILT IN CROSSOVER WITH EXTRA KNOB TYPE ADJUSTMENT FOR FINE TUNING
Connection 1
Connection 2
March 19th, 2009 03:01 AM #14
Tama yan. You can use the 3&4 channel(+3)/(-4) also switch your amp to mono if your amp have a selectable crossovers for your sub's only, then use 1&2 channel for for both rear speakers.
March 26th, 2009 03:30 AM #15
any feedback for America Lumina Nano Ceramic ? which better between Sunblock Ceramic vs Lumina...
