Results 81 to 90 of 124
- Jul 2010
- 165
February 28th, 2011 01:24 PM #81The positive live wire should exist in your car. If you can't find it, you can route one from the battery to your stereo and don't forget to add a fuse just in case.
The wire labeled with memory on the CDR King stereo is connected to the positive live wire(this wire is colored yellow). The red wire is the one connected to the accesories.
- Aug 2003
- 13
February 28th, 2011 02:20 PM #82
- Jul 2010
- 165
March 1st, 2011 08:51 AM #83
- Sep 2004
- 340
March 1st, 2011 02:44 PM #84http://cdrking.com/index.php?mod=pro...=8597&main=108
parang gusto ko testingin ito. may mosfet pa, 45Wx4. eto lang ang may heatsink sa likod sa lahat ng inoofer ng cdrking so most probably mosfet nga. talo lang ako sa erpats ko at walang AM band ito.
- Aug 2003
- 13
March 1st, 2011 04:04 PM #85*normanenoza
Mukhang ok nga yan. Mas malaki ang display at mosfet pa. Malamang may AM rin yan. Yun sa akin, sa FM band nakukuha yung AM signal. hehehe.
Di ko lang gusto riyan yung cover ng SD/USB ports. Napaka-flimsy.
Tsaka wala siyang AUX-in kaya di ko kinuha.
Otherwise, mukhang ok naman siya for 980.
- Sep 2004
- 340
- Apr 2011
- 2
April 5th, 2011 06:09 AM #87mga bossing tanong ko lang po... anong format nung usb/memory card na ginagamit nyo? sakin kase pag lagay ng usb/memory card fm pa rin ung lumalabas... patulong naman po.. windows7 gamit ko na OS
thanks
- 168
- Aug 2003
- 13
April 5th, 2011 11:49 AM #89Yup! Fat16 naman ang usual na format when formatting from windows.
Kung FM ang lumalabas, baka hindi mo nase-select ang "Mode". Pressing the mode button makes you cycle through the available modes. In my case, I have 3: USB, AUX, FM(Radio).
- Apr 2011
- 2
April 5th, 2011 03:46 PM #90mga idol salamat..
one problem though, wala pong fat16 na option sa windows 7?? fat, fat32, ntfs saka exfat lang po...
now i tried searching for solutions using google, tapos sabi use fat since its the same with fat16...sinubukan same problem po...
sorry newbie...
thank you sa tulong!!!
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
