Results 1 to 10 of 21
- 24
November 18th, 2002 10:09 PM #1I have a 2pcs. 15 inch speaker bili ko raun and it was used as an outdoor sound system.Tanong ko lang kung pwedeng gawan ng buffles para sa trunks? Is it possible to use 2 15inch speaker??????
November 19th, 2002 01:58 AM #2
pwedeng pwede...i used 2 15inch MTX subs in my 96 honda civic...
PEACE!!
- 10,620
- 229
November 19th, 2002 03:39 PM #5
ice27
brod tanong lang ok ba yang brand na yan kasi may benta sa akin na isang set na sub and ampli, mtx brand ok ba ito di ba matigas ang tunog nito yan kasi sabi friend ko matigas sya.
thanks in advance
- 10,620
November 19th, 2002 03:57 PM #6pareng jake,
the best pa rin is to audition the speaker then let your ears be your guild
- 31
November 20th, 2002 09:50 AM #7Originally Posted by eljo
since this was used as an "outdoor" speaker, i guess the impedance would be around 8ohms...if this is the case...best to wire it parallel so you get a 4ohm load...hth
November 20th, 2002 12:26 PM #8Originally Posted by Silver
meron po akong;
HU Alpine 4x25watss w/ 6 CD changer
Amp Thump 4x75watss
at di pa naka set-up sa tsiko ko. ano kayang match speaker para d2?
mas gusto kong set up ay yung balance ang tunog sql bayun? ano kaya kailangan kong speaker?
yung sa door pannel ayokong butasin kase stock car sayang naman....
yung sa likod naman po hatchback ang door kaya buong dash board umaangat once i open my rear door.
any suggestion?
salamat in advance.... :lol:
- 31
November 20th, 2002 12:38 PM #9parallel is to wire + to + and - to -, you can do this with 2 single voice coil speakers or 1 dual voice coil speaker. wiring them parellel will halve the impedance from i.e. 8 ohms to 4 ohms or 4 ohms to 2 ohms etc..etc
series on the other hand is the opposite...+ to - to + to -, this will double the impedance of your speaker...
difference perfromance wise between 8 0hms and 2 0hms...WALA but since car audio amps are rated at 4 ohms...it is best you use this rating so your amp can perform to its optimum level. now, why do some go for 2 ohms or lower? well, this is to maximize the power that an amp can give as long as it is stable enough to handle such a load.
hth
November 20th, 2002 01:02 PM #10Originally Posted by Silver
ANY SUGGESTION :!: :!: :idea:
meron po akong;
Amp Thump 4x75watss
at di pa naka set-up sa tsikot ko. ano kayang match speaker para d2 :?:
mas gusto kong set up ay yung balance ang tunog sql bayun or sq lang :?: ano kaya kailangan kong speaker or kailangan ko pa ng Xover :?:
yung sa likod naman po hatchback ang door kaya buong dash board umaangat once i open my rear door. ano kaya magandang gawin dito :?:
:roll: :roll: :roll: :roll: :roll:
Traffic!
