Results 11 to 20 of 28
- Sep 2003
- 342
November 16th, 2006 10:39 AM #11ayun...tamang tama ito.. 7K at bnew pde na pero mas oks kung meron may magbebentang 2nd hand nito para medyo mura..hehehe
thanks..
- Sep 2003
- 342
November 16th, 2006 10:50 AM #12sir i just called ang autoline...eh overkill na daw yun... kung daw JL10W3v2 eh dapat mga 200watts to 250watts lang kase daw para di masunog ang sub...
any other model ng jbl na mga nasa 200-250watts lang?
- Sep 2003
- 342
November 16th, 2006 10:57 AM #13sir i just called ang autoline...eh overkill na daw yun... kung daw JL10W3v2 eh dapat mga 200watts to 250watts lang kase daw para di masunog ang sub...
- Feb 2005
- 109
November 16th, 2006 11:10 AM #14there's nothing wrong with over-powering a speaker as long as it's tuned properly and level-matched. mas makakabuti nga na over-powered para sure ka ng hindi clipped signals yung ipapadala ng amp mo to your sub. maganda rin na medyo malakas ang amp mo since JL subs work best in sealed enclosures. mas magiging buo yung tunog with a bit more power feeding it.
- Sep 2003
- 342
November 16th, 2006 11:12 AM #15sir btw, talagang kaya naman ng 10w3v2 ang JBL CS 300.1 san po makakahanap na shop nito...appreciate shops where i can find this amp and phone number...
- Feb 2005
- 109
- Sep 2003
- 342
November 16th, 2006 11:20 AM #17ayos..then i'll just look for this sub... i guess would just be fine then..sabi i control ko nalnag gain power to at least half para sure ako ng di sunog ang sub...
- Feb 2005
- 109
November 16th, 2006 11:27 AM #18saan mo ba plano maghanap ng sub? you might have a hard time na rin, since w3v3 na ang usually nakikita kong binebenta sa shops.
- Sep 2003
- 342
November 16th, 2006 11:33 AM #19shop in makati... aside ba sa autoline wala na ba oks gumawa ng box at mag setup or install na malinis at pulido? kase yung iba parang business as usual lang sa paggawa..u won't see the passion sa kanila in doing things the right way...
any shop you think na oks din around makati?
November 16th, 2006 11:34 AM #20
vsm712,
fukengruven's enclosure is ported, so it's bigger than the .8 cu ft - 1 + cu ft recommended size. it'll play louder but it won't be as accurate in terms of SQ. but then, SQ is subjective, too. hehe! ported enclosures require less power than sealed enclosures. or should i say, you should be a bit more careful in tuning your system with a ported enclosure since with the same power, it'll play louder (and burn your sub more easily) than with a sealed enclosure. don't fear this phrase too much though ("burn your sub more easily"), alalay lang sa pag tono.
I don't even bother reading articles about Chinese cars. Sent from my SM-T970 using Tsikot...
2024 Manila International Auto Show APRIL 4-7,...
