Results 11 to 18 of 18
November 24th, 2006 10:23 PM #12
Any comments ba with crystal X2? 1600rms daw eh..im thinking of having 1 15'in pasok na box size should not exceed 54x17x16 kasi i already have amp rack sayang if babaguhin pa.
November 25th, 2006 03:15 PM #13
November 26th, 2006 02:13 AM #14
Fs-23.5hz Qts-0.52 Vas-4.2 ported daw sir required for spl kasi sub na to. have knowledge of rear horn type na box?
November 26th, 2006 09:26 PM #15
Based on the above parameters, it turned out the following:
1. For optimum ported box, volume of 9.644 cu.ft. will have a box resonance frequency of 17.78 down to 15.26, which you can't almost hear it anymore. As a compromise, try 4.2 cu.ft, which will give you a resonance frequency of 23.5 hz. If you don't have the instrument to test this frequency, it will be hard for you to decide for the port dimension.
2. For optimum closed box, volume of 4.95 cu.ft. will give you an optimum box resonance frequency of 31.95 hz. (I preferred this one).
If you want a harder bass, go for 2.177 cu.ft with a resonance frequency of 40.22 hz.
Volume is the net volume. Approximately add an additional 10% volume to compensate the volume covered by your drivers.
Horn type box are designed for external use like open space. I don't advise this for car application.Last edited by busy road; November 26th, 2006 at 09:29 PM.
November 27th, 2006 09:29 PM #16
ok,sir medyo mahina po ako sa frequency(hz) any suggestion kung san makakatulong sakin sa pag gawa ng box or shop? may setup na po kasi ako and gusto ko lang yung boy lang ng subs ang mabago at wag na amp rack,wala pa po kasing 1month setup ko and now lang talaga ako naka pagdecide. i'll post pics some other time so you can give me guys suggestion on what i can do.tnx po pala sa oras
November 27th, 2006 10:24 PM #17
meron nagbebenta ng dd3515d with ported box sa kotseaudioclub.com. look for paul ferrer. 20k ata niya benta. gawa ni mickey yung box.
naka audi ako ng 3512d + t1000 lakas din!!
November 28th, 2006 12:00 AM #18
pepengtom-have you auditioned mmats P3 15'? sin lakas kaya nun?my na auditioned ako DD but ay dont know the model pero malakas din pwede credit card?hehe
