Results 11 to 19 of 19
February 1st, 2008 05:23 PM #12
maraming salamat sa mga replies nyo!
full of info and tips that i have noted down.
later that night, i found out a different thing that caused that freaky stalling.
napa-start ko pa ulit - 1 click. then i traveled a little distance, nun mejo nakalayo na ako from home, napansin kong mejo naghihingalo na uli ang takbo. hirap humatak kahit 1st gear. then may naamoy akong hindi maganda coming from inside the hood. mejo pumangit narin tunog ng makina.
ayun overheat pala ang loko. good thing nasa secondary road lang ako at wala masyadong dumadaan where i could cause traffic. pinalamig ko muna then nun nilagyan ko na ng water yung radiator, sinusuka pa uli ng radiator, then i continued on sa paglagay ng water. in the end, nakauwi pa uli ako.
then kinabukasan, chineck ko yun ilalim while filling up in a gas station, nakita ko nga na may tumutulong tubig from the engine ata? (not sure pa till now kung saan un). kaya alaga nalang muna sa paglagaylagay ng water sa radiator.
on my free time, ill have it checked and fixed para maibyahe ko narin ng maayos un ride. by the way, it's a different car - nissan sentra boxtype. nakakapagsounds na uli ako as normal, pero overheating issue mangyayari if in case maubusan ng water.
im just wondering kung saan kaya exactly un source nun? hirap kasi silipin, mababa un koche. di ko pa natry umilalim uli dun.
sorry guys, false alarm pala about the electrical issue. but thanks for your shots. pero i still have the concern with the restarting of HU's memory every time i fully switch off the ignition. 1 lang power wire nya eh, then black na un 1 pang wire (ground) the others speakers at power antenna.
thanks
February 1st, 2008 05:45 PM #13
ngee wag mo muna gamitin car mo baka kumatok. kung nag-overheat na then you pour water, the tedency is mag warp yung cylinder head. lalaki gawak kapag ginamit mo pa. pa check mo muna bago gamitin
February 1st, 2008 09:31 PM #14
February 1st, 2008 09:53 PM #15
have your water pump checked.. tignan mo kung may leak sa small hole dun--kung may water stains--palitan mo na..mahal magpamachineshop ng head...
- Jan 2008
- 154
February 14th, 2008 05:17 PM #18dude pagsama- samahin na natin yung mga possible na cause
1. mahina maggenerate ng power alternator mo
2. Mahina na battery mo possible if luma na
3. wala kang fuse,, malakas kumain ng power and amp at Sub
check mu muna parts then try mo lagyan ng capasitor yung power papunta sa sound system mo
