Results 21 to 29 of 29
July 11th, 2006 11:01 AM #21
bro, maybe your expecting too much from your budget setup, don't overdrive your amps baka masira lang. Your amp, the V12 705, isn't a power amplifier (trust me here). If your really serious about SPL consider getting Class D amps (mono amps designed to power subs), these babies deliver serious power (depending on the model) and is more efficient. Ofcourse with more power, you will stressing your charging system more so its a balancing act.
July 11th, 2006 11:05 AM #22Originally Posted by happy_gilmore
or 1 15"..
July 11th, 2006 11:19 AM #23Originally Posted by ILuvDetailing
I just wondered why this was the case. Kanina as suggested I tried stepping a few feet away instead, and dinig naman yung bayo.
Right now upgrading is out of the question, mga 2 weeks pa lang nga yung system ko e. Pero of course pag inabot na'ko ng upgrade bug, ewan ko na lang.
July 11th, 2006 11:26 AM #24
Its not in the # of subs, its all in the installation, and ofcourse it component matching.
I'm sure you guys went to the motorshow in Megamall. Did you see Auto+'s entry, its 2-12" JL W7's but it was loud very loud. Compare it to Alpine's entry, all 6 or so 12" Type R subs could't match JL's output in terms of Dbs. However there is a silver lining, mas mura yung Type R's ng alpine, while those W7's will set you back around 35K and up. Amps will also set you back 30++k. You see if you want it loud prepare to spend a lot of moolah.
Tsikot Member Rank 4
- 2,716
July 25th, 2006 03:32 PM #27
tama si boss ILUVDETAILING it's not in the no.s ksi po i own a 15"L7 1pcs at may clm8 ako na naka 2 15 na dd talsik sya skin yng kanya sumasagad na skin nag paparamdam pa lng :D. E1 ko kng masyado mali ang box nya or what. The fact is mas maganda pa ampli nya skin skin x-plod lng na 1100watz sakanya directed na 1000rms.
July 25th, 2006 03:35 PM #28
and how thin/thick your car panels are hehe... you'll have a hard time hearing bass from the outside with a Benz compared to a City hehe.
July 25th, 2006 03:42 PM #29
yeah pansin ko rin dati sa setup ng bimmer ko, di syado rinig sa labas while sa mga katropa na naka civic n city lakas ng bass kahit closed ang trunk n doors
sa area ko ang dami choices ng emission testing. Bale 500pesos the lowest in my area. Sa iba nasa...
LTO accredited emission testing centers
