Results 21 to 30 of 151
February 13th, 2023 02:48 PM #21
ganyan din ako before buying my unit.
does it have enough RAM? (kaya I bought the mid-range model)
what CPU is it using? what Android version?
later I learned (after playing with my Growl HU) na di pala pwede iupdate yung Android version (its just not available sa system settings)
CPU/RAM? as I said, mid-range gamit ko and masaya naman ako sa UI nya.
My SA from Honda is using the cheapest version and ok naman din sya, still better (daw) than AVT
Apps will work (except for Netflix). they will also get updates.
so far, no complains. I even forgot na kung anong Android version gamit ng Headunit ko.
- Sep 2016
- 2,277
February 13th, 2023 04:58 PM #22
February 13th, 2023 06:02 PM #23
di ko na chineck if tama ba specs o anong android version[emoji28]. so far ok naman interface niya sa android phone. kumukonekta naman sa spotify, yt, at navigation apps. i got the 7.9k both sa suv and van ko. tunog wise, swak lang din. my suv have bewith front speakers while the van have focals both front and rear.
Sent from my SM-G960F using Tsikot Forums mobile app
February 13th, 2023 06:48 PM #24
IMO... way better than the AVT na binili ko sa Honda for almost 50K!
only benefit nung AVT is that the reverse cam activates a split second faster.
- Jul 2009
- 2,618
February 13th, 2023 06:59 PM #25
February 13th, 2023 08:26 PM #26
Nope. Been there, done that. I just didn't bother changing ours until we sold the unit because I was really just after a larger screen for Waze.
February 13th, 2023 11:21 PM #27
ok naman, solid ang midbass, i don't even need a subwoofer. can't compare sa focal na nasa van, more on sa A/V support kasi set-up nun.
btw, the bewith ay yung entry level na BeFIT. bought pre-owned 2014 pa yata, had it installed by simplesounds.
February 14th, 2023 11:11 AM #28
Astral advertised Netflix, pero it's just an old apk file. Deleted it since wala naman akong Netflix account. Advantage of having an Android is you can change everything. Installed Car Launcher app and customized the screen to my preference. Installed Sygic maps app for offline use, Prime Video, Poweramp music app, VLC, Vanced YT and YT Music. Cross fingers it will last next five years...
February 14th, 2023 11:25 AM #29
February 23rd, 2023 10:49 AM #30
Ano ginagamit na equalizer app na pwede sa Spotify? Ayaw gumana yung built in equalizer ng Astral/Alps HU....
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
