Results 11 to 19 of 19
- Jan 2010
- 283
October 28th, 2017 08:32 PM #11
- Mar 2017
- 4
October 28th, 2017 09:26 PM #12[QUOTE=dr. d;2890582]have your alternator seen by an alternator specialist, po. (yock's comes to mind.) they'll also check your system, to make sure that it is indeed, the alternator...
sometimes, all that is needed is to replace the electronic module inside. it's still cheaper than purchasing a used or new alternator.
and, done properly, it'll last many more years.
of course, purchasing a brand new alternator is an easy fix.
the assumption is, you do not have any power-hungry appliances in that car.[/QUOTE
Sunog daw Sir ang alternator at nakita ko din medyo sunog nga. Pwd n din cguro yung 70 amp n alternator😊 5k ung bago pag surplus kc mga 4k hnd nmn din nagtatagal like n nangyari ngyon
- 52,731
- Feb 2018
- 65
February 5th, 2018 05:03 AM #14You def don’t need a high powered alt unless you running 1000’s of watts...
first check if your alt is working correctly..
car switched off should be 12.4v , car switched on should be 14.4v
Next get a bigger battery and do a big 3. Search google for ‘big 3’ if you not fimiliar with this term.
If still you having electrical issues, then check your relay, that might be damaged and draining current
- Jan 2018
- 23
January 4th, 2019 11:38 PM #15
- Apr 2010
- 91
January 6th, 2019 01:18 PM #16
- Jan 2018
- 23
January 8th, 2019 04:06 AM #17
- Jan 2019
- 8
January 24th, 2019 08:21 PM #18Looking for the best 3000-watt amp to take your car audio system to the next level? Worry not as we have compiled a list of the best 3000-watt amps in the market today.
The reviews are meant to help you with making a decision. Ultimately what you chose will boil down to personal preferences and personalized requirements. We can guarantee that the reviews are for the best 3000-watt amps regardless of what you chose.
Quick check best 3000 watt amp in 2019
AUDIOPIPE APCL30001D 3000 WATT MONOBLOCK CAR AMPLIFIER
Hifonics BRX3016.1D Brutus Mono Super D-Class Subwoofer Amplifier, 3000-Watt
Pyramid PB2518 3,000-Watt 2-Channel Bridgeable Mosfet Amplifier
BOSS AUDIO PD3000 Phantom 3000-Watt, 1, 2, 4 Ohm Stable Class D Monoblock Car Amplifier with Remote Subwoofer Control
Planet Audio TRQ1.3000D Torque 3000-Watt Monoblock Class D 1 to 8 Ohm Stable Monoblock Amplifier with Remote Subwoofer Level Control
NEW VM Audio EXA3000.2 3000W 2 Channel Car Amplifier Power Amp MOFSET Stereo
Visit This Website for more info.
- Nov 2018
- 3
