Results 1 to 9 of 9
- Dec 2008
- 11
December 8th, 2008 11:48 AM #1hELLO AGAIN GUYS!!!
What will i add this is my present set up
H.U = Alpine 9884
Front = DLS ms6 seps
Rear = Same ms6
Amp = jbl cs60.4 4 cha
sub = dls w312d 200wrms
Considering im looking for good SQ set up need your advise and opinion on what to Add Thanks
December 8th, 2008 02:57 PM #3
electronic crossover
change the location of the seps from the door to near clutch area for better output of sounds
add a center speaker
add mono amp for the subs and let the current amp power the seps.
baka sa mods na ito, kailangan mo na better alternator to power those hehe.
hth
- Dec 2008
- 11
December 9th, 2008 03:46 AM #5
Deaden your front doors it can do wonders JL and DLS combo are known for SQ try mo tuning and driver placement, try adjusting tweeter position if its in A pillar. But if you really want to spend for the upgrade then invest in high end 2 or 3 way seps.
BTW whats powering your sub? the channel 3-4 of jbl cs60.4 ? and how did you power your two MS6? my opinion ditch the rear fill mahirapan ka lang e tono if you want SQ..
December 9th, 2008 04:26 AM #6
Mang Boy yung MODS po ay "Modifications"
By they way, did Kid Audio placed some deadening in your car? Like on the doors, car ceiling or flooring? Just like what Sir Gonzo has mentioned?
These deadening materials can enchance the sound quality of your set-up kase.
Some good ones like Dynamat, Dynaliner and Accumat were used in my sound set-up. I had them all done around the car except for the ceiling because the car had good acoustics naman even before pa. I just needed more deadening at the surrounding areas like the doors, flooring and the back of my car where the subs, amps and crossovers are located.
December 9th, 2008 09:40 AM #7
aside from the deadening you may change your amp.
get a dedicated amp for your seps and another amp for your sub.
December 16th, 2008 12:12 AM #8
if you want sq.
disable rear fill.
get a midbass hertz dsk is good for sq.
add amplifier. separate the amp from the seps and the sub.
dedeaning.
+ good wires hehe
- Nov 2008
- 123
December 16th, 2008 02:30 AM #9Mangboy..Sa Alpine mo na HU (CDA-9884R ba ito) nagagamit mo ba ang lahat na feature? Kung CDA-9884R yan..kung meron kang PXA-H100 magagmit mo yong SOUND IMPRINT sa stereo( eg. MULTI-EQ ,CROSS-OVER ETC..) Kung meron ka pwidi paki post kung saan mo siya nakuha na mura .. dahil sayang yong nabili namin na Alpine pagwla kasi itong PXA-H100 hindi magagamit yong ibang features niya..Thank you! By the way..yong current set-up mo upgrade na yan sa iba ..correct me If Im wrong mahal pa yata sa HERTZ DSK ang DLS MS6 mo..sa akin Ang dapat mo lang palitan ang CS60.4 lakihan mo ang RMS power.. the bigger the power the cleaner ang tunog sa set-up mo.. Post ka ng pictures soon..
