Results 1 to 9 of 9
January 31st, 2008 12:24 AM #1
ok lang po ba 2ohms car speaker ko sa 4-8ohms na car stereo? if not any mods na pwedeng gawin.
January 31st, 2008 12:40 AM #2
Kung ang lowest impedance na puwede sa stereo mo is 4 ohms, di talaga puwede ang 1 na 2-ohm speaker. Dapat talaga 4 ohms lang ang min. Per0 kung may 2 ohms ka na speakers, puwede kang mag series ng 2 para ma meet ang 4 ohms na minimum.
January 31st, 2008 01:31 AM #3
ty po sir...may masisira po ba sir if ever ituloy ko gamitin? bibigay kya ung car stereo ko or speaker?
January 31st, 2008 01:41 AM #4
January 31st, 2008 01:59 AM #5
^ The stereo I beleive will breakdown soon.
Since my guess is that your 2 Ohm speaker would have a higher RMS rating than your stereo anyway...why don't you buy a small bridgeable amplifier to give that speaker some power. Usually car stereos only have 25W RMS per channel...so an amplifier would make a difference.
January 31st, 2008 03:31 AM #6
thank you po sir DONT...O.T...dubai ko po nabili ung JBL gto 637 6.5 ko lam mo naman sir mura sa M.E. ex-dubai po ako. sarap pa konti weather dyan but after january hehhehhe mas masarap sa loob ng office na lang.
January 31st, 2008 11:33 AM #7
January 31st, 2008 08:49 PM #8
Puwersado ang amplifier mo. At certain level of output power, baka bumigay ang mga power IC's or transistors due to high output current.
Assuming the maximum output power of your amplifier is 100Watts * 4 ohms impedance.
Using 4 ohms speaker,
I current^2 = Power/Impedance = 100/4
I current = 25^1/2 = 5 amps.
Using 2 ohms speaker,
I current^2 = Power/Impedance = 100/2
I current = 50^1/2 = 7.07 amps.
With the above comparison, your amplifier will be driven by 7 amps against 5 amps. As a compromise, limit your volume at 50% only.
February 1st, 2008 12:22 PM #9
i agree, mago-overheat ang amp mo if you set it up that way. . .for maximum power transfer, the output impedance of the source should be equal to that of the load. . .pwedeng mas mataas ang input impedance ng speaker than the amp but not the other way around because of the effect as mentioned above. . .
sabi nga ni meledson, you can connect 2 2-ohm speakers in series (not parallel, magiging 1 ohm ang total impedance nyon. . .reverse effect) to solve it or you can use an "impedance-matching adapter" (tanong ka sa raon). . .
peace of christ!
"THOUGH HOME TO US ALL, THE EARTH IS MUTE.
IT DOESN'T GET A VOTE IN ANY CONGRESS OR PARLIAMENT.
IT DOESN'T OWN BLOCKS OF SHARES IN THE MARKET.
IT DOESN'T RISE UP AT A PROTEST RALLY.
IT CAN'T EVEN BUY A HYBRID CAR.
THE EARTH HAS NO VOICE--SO WE MUST SPEAK FOR IT."
Traffic!
