Results 11 to 16 of 16
- 19
March 25th, 2008 01:35 AM #12
- 19
- Feb 2008
- 8
March 27th, 2008 07:17 PM #14ganda na yang sub mo a.. mga 750rms yan.
kung isang s12l7 dvc4 ang gagamitin mo, better get a 750wrms or higher *2ohms mono amp. kung 2 subs gagamitin mo, get another s12l7 dvc4 and get a 1500wrms or higher mono amp *1 ohm stable.
tapos ported box
kung kaya pa ng budget get a high voltage hu.. mga 4volts or higher.
boom boom na yan!
hth :D
- 19
March 28th, 2008 06:28 AM #15boss ano magandang mono amp na may 750 rms * 2ohm?
puwede ba sa 4ch amp yung sub given na naka bridge ito?
- Jan 2008
- 4,726
March 28th, 2008 04:41 PM #16DVC subs only allow you to have flexible wiring capability since you can wire them at 2ohms, 4 ohms and 8ohms..
do not connect this where in a single DVC sub was connected to a 4channel amp at bridged, the setup was channel 1&2 was bridged then connected to the Sub at 4ohms then channel 3&4 was also bridged and connected to the same sub on the other side..
your amp will overheat and your sub will not play properly..
also you may use HU with 4V to 5V line out
