Results 11 to 19 of 19
- Aug 2012
- 2,767
October 26th, 2015 06:01 PM #11
- Aug 2012
- 2,767
October 26th, 2015 06:01 PM #12*double post*
- Apr 2017
- 11
April 12th, 2017 02:47 PM #13Hello. the stock head unit of toyota vios 2015 is mirrorlink ready meaning you can use the head unit as a display from your smartphone. You can also use the display to navigate your smartphone. I hope this helps.
Cheers
April 13th, 2017 10:43 PM #14
The BT is purely useful for audio streaming
USB is for reading music files or power supply
HDMi is for any hdmi device like a digital tuner or mirroring (streaming screen image via wifi) device. a google chrome or miracast device, get the device that is compatible to your smartphone. Attach it to the hdmi port of your headunit. Configure your wifi hotspot and make the proper settings to connect the smartphone and the mirroring accessory into the hotspot and youre good to go. Theres no need to buy a high end head unit
If the stock unit has an ip configuration already then theres no need to get a mirroring accessory
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; April 13th, 2017 at 11:08 PM.
- Sep 2017
- 5
September 5th, 2017 10:48 AM #15Anyone whos has tried the wirless mirroring route via miracast if it really works?
AnyCast Miracast 1 8 P Wifi HDMI Display Dongle Receiver DLNA TV
Airplay | Lazada PH
Im tempted to buy this, im just not sure if its going to work with the vios HU with hdmi
- Sep 2017
- 1
September 27th, 2017 10:46 AM #16mga sirs, bago lang din po ako dito. Hindi pa pwede gumawa ng new post.
nakakuha ako ng 2nd hand vios E, 2nd gen. Gusto ko sana palitan ang stock na stereo. CD player lang ang meron, ni hindi masaksakan ng AUX in.
any advice? hindi naman ako pilian, tipid din sa budget, basta matibay lang at kung pwede meron kahit usb or aux in man lang.
salamat
September 27th, 2017 11:13 AM #17
First and foremost the device you intend to mirror like a tablet or a smart phone must be compatible with the miracast device
- Apr 2010
- 739
September 27th, 2017 11:32 AM #18I believe may AUX-in capability yan using a proprietary cable, mas mura ito than changing the whole head unit
Meron sa Team-BHP and this is for a Fortuner though pero I would assume similar lang sila:
DIY - How to Remove stock stereo of Toyota Fortuner & Install iPod/Aux functionality
- Jun 2012
- 4,448
September 27th, 2017 07:12 PM #19
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
