Results 1 to 8 of 8
June 22nd, 2010 10:43 PM #1
Hi, my clubmate is selling me his 15" Alpine type R sub woofer w/ MDF box and some wirings for 14k. tanong ko lang kung sulit na yung presyo nun? newbie palang din ako sa audio systems. bali ikakabit siya sa innova and 2 months palang niya nagagamit yung subs. thanks in advance!
- Jun 2009
- 325
June 23rd, 2010 10:50 AM #2Just asking, is the amplifier included in the package? If not, its expensive.
- Jun 2010
- 6
June 25th, 2010 02:52 AM #4
actually guys wala pa siyang amplifier na kasama, he lowered it down to 11k w/ box na. I'm not familiar with prices when it comes to car parts like these, bali yung sub woofer lang mismo nabili niya for 16k from canada then yung MDF box pinagawa niya ng 4k ata. i still have to find a new amp if ever na bibilin ko yung kanya, another friend of mine is selling his sound magus amp for 12k, nagugulat ako sa prices kasi may nakikita ako 30k all in na pero i doubt it kung maganda ba. thank you sa mga nag reply at mag rereply pa.
June 27th, 2010 03:01 PM #6
eto pala specs mga sir:
Subwoofer Specifications
Subwoofer Size 15"
Subwoofer Design Round / Circle
Main Cone Color Silver
Voice Coil(s) Dual (2 voice coils)
Impedance (per voice coil) 4 ohms
Peak Power Handling 2000 watts
RMS Power Handling 750 watts
Woofer Composition N/A
Woofer Surround Santoprene Rubber
Minimum Sealed Box Volume 1.75 cubic feet
Maximum Sealed Box Volume 1.75 cubic feet
Minimum Ported Box Volume 2.9 cubic feet
Maximum Ported Box Volume 2.9 cubic feet
Sensitivity 87 dB
Frequency Response 20 - 400 Hz
Xmax (millimeters) N/A
Top Mount Depth 9.2"
Shallow Mount Installation No
Cutout Diameter 13.8"
Recommended Enclosure Type Ported / Vented
Sealed
Subwoofer Grille No
Re-Cone Kit Available No
Warranty and Return Policy
Return Policy Standard Return Policy
Parts Warranty Duration 1 year
Labor Warranty Duration 1 year
Warranty Provider Sonic Electronix
Alpine Type R Subwoofers
These incredible subwoofers from Alpine have withstood the test of time and proven themselves to be one of the top subwoofer choices for car audio enthusiasts. The Type R subwoofers are designed and engineered for big bass, as well as a durable sub that will last for many years to come. These woofers use a pulp cone that is reinforced with Kevlar for an incredibly durable and rigid structure. The ribbed multi-roll santoprene surround is designed for excellent response, while assisting in smoother cone movement and excursion. The subwoofer will stay cool under extended hard playing with the unique thermal management system that Alpine designed into the Type R Subwoofer. The tinsel leads are hidden and woven into the dual Nomex spiders for a strong and unbreakable connection. For those looking for an industry standard subwoofer with break-taking bass, consider the Alpine Type-R subwoofer.
15" Dual 4 ohm Type-R Subwoofer
Power Handling:
Peak: 2000 watts
RMS: 750 watts
Parabolic kevlar/pulp fiber cone
High amplitude multi-roll santoprene surround
Cast aluminum perimeter vented heat transfer frame
Compound Radius Curve (CRC) Motor structure
Spiral cut aluminum former with high temperature DVC Winding
Radial Vented (VC) heat sink and Airflow Management System
Mirrored progressive nomex spiders with reinforced layer integrated tinsel leads
1-year SonicElectronix.com warranty
Alpine products are warranted solely by Sonic Electronix, Inc. under the same period and terms as the original Alpine warranty. Sonic Electronix is not an Authorized Alpine Dealer and Alpine requires all merchandise purchased by Sonic Electronix customers to be returned solely to Sonic Electronix. Alpine products are also covered by our Standard Return Policy for returns on exchanges or refunds within 30 days from the date of purchase.
- Dec 2007
- 366
July 1st, 2010 12:11 AM #8
