Results 231 to 240 of 248
Thread: Avanza Headlight Upgrade
August 15th, 2011, 05:40 PM #231
Re: Avanza Headlight Upgrade
ayus yan si Ginnova...magkano po score nyo dyan?
August 15th, 2011, 07:13 PM #232
yung projector is sourced out in China. DIY installation lang. marami na sellers at installers dito sa atin.
August 16th, 2011, 11:30 AM #233
- Jan 2009
- 62
guwapo ng ilaw, sir ginnova! ask ko lang po paano yung hi-beam? dual beam yung projector?
sorry po, wala akong alam sa mga hid kasi
August 16th, 2011, 03:14 PM #234
bi-xenon projectors has high beam function. a cut-off shield is used to block portion of the light at low-beam. on high beam mode the shield is pull down to expose most of the light. only 1 light source ( hid bulb ) is required for both hi/lo operation.
August 17th, 2011, 05:30 PM #235
- Jan 2009
- 62
ganun pala yun, thank you sir! magkano po lahat damage sir?
August 17th, 2011, 10:18 PM #236
kung diy install. around 10K . 55watts ballast with additional shroud.
August 17th, 2011, 11:03 PM #237
^ sir napansin ko ung fog light mo..naka projector din ba yan?
August 17th, 2011, 11:13 PM #238
oo. same projectors as headlight without the additional shroud.
August 19th, 2011, 06:59 PM #239
thank you for this information. if ever na mag upgrade ako ng head light at fog light. i will send you a PM for another inquiry...again thank you..
August 20th, 2011, 12:04 PM #240
here's a better demo on how bi-xenon hi/lo works.
cut-off shield is pulled down to expose more light during hi beam.
Kung bago na ang throttle body at servo motor, ang next suggestion i check sa YT search ay. 1....
LANCER Itlog (93-96) Owners - Please Post Here!
